Question about HP Photosmart 3210 Printer
Changing from USB to networking on hp 3210
Im changing my 3210 to connect from the network vs a direct USB connect on one of my servers and I can't figure out to the the HP Solution Center application to recognize (or change the connection configuration) to recognize the device after changing its connection to a network...
Thoughts?
You have to uninstall the printer software and then reinstall it, chosing the connect through network option.
Posted on Jul 30, 2009
Can i make a hp2420d a network printer
You can purchase a jetdirect network card from Ebay. Any model will work, a 610 should not be too expensive these days. Or you can purchase a USB network print server and connect the printer to the USB port on the printer and then connect the print server to your network.
Aug 10, 2014 | HP Office Equipment & Supplies
How can i use hp 3210 all-in-one printer with toshiba chromebook
The 3210 can be connected either through a USB port directly to a computer or ethernet cabled to a router or switch. Either will work. Personally, I would connect it using ethernet (~$15 for a cable) because then it becomes a common resource on your home network.
Jun 14, 2014 | HP Photosmart 3210 Printer
Nas unreachable on network
Try connecting a USB mouse & keyboard DIRECTLY to the back of the server (plugging the monitor directly into it as well) then login directly instead of over the network. Repair may be possible if successful.
Dec 16, 2012 | LaCie Space 2 (301515EK) 1000 GB Network...
How can i install hp designjet 5500 PS on my com puter using network cable? My plotter (hp designjet 5500) do not have USB port instead it has netwok port from which one can install via the local network...
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Apr 15, 2011 | HP DesignJet 5500PS InkJet Printer
How do I connect my wireless laptop to the hp photosmart 3210?
If the printer doesn't already have network capability, you'll need to use a USB print server. Here's an example. You connect the server to one of the router's wired ports, and then any network computer (wired or wireless) will be able to print to the printer.
Jan 20, 2011 | HP Photosmart 3210 Printer
У меня HP Photosmart 3210
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP Photosmart 3210 All-In-One InkJet...
I put in new ink an it is giving me a OXC18a0106 error
  • Connectivity :
Oct 26, 2010 | HP Photosmart 3210 Printer
Error message when trying to copy a document: Paper size detected is not supported. Job cancelled.
  • Connectivity :
Oct 26, 2010 | HP Photosmart 3210 All-In-One InkJet...
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Can I connect the printer directly to my laptop using ethernet cable
Hi! If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies. For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab. NOTE: Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel. Access the Embedded Web Server Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
  1. Press Setup on the HP All-in-One.
  2. Press c00706174.gif until Network is highlighted, then press OK . The Network Menu displays.
  3. Select View Network Settings menu, then press OK .
  4. Select Print Network Configuration Page , then press OK . A configuration page prints, including the IP address. You will use the IP address in the next step.
  5. In the Address box in the Web browser on the computer, type the IP address of the HP All-in-One, as shown on the network configuration page. For example, http://192.168.1.101 . The Embedded Web Server Home page displays, showing information for the HP All-in-One. NOTE: If you are using a proxy server in your browser, you might need to disable it to access the Embedded Web Server.
  6. If you need to change the language displayed in the Embedded Web Server, do the following:
    1. Click the Settings tab.
    2. Click Select Language in the Settings navigation menu.
    3. In the Select Language list, click the appropriate language.
    4. Click Apply .
  7. Click the Home tab to access device and network information, or click the Networking tab to access more network information or to modify network information.
  8. Make any configuration changes.
  9. Close the Embedded Web Server.
Good Luck!
Oct 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
212 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
