Today I bought and installed a Linksys Wireless-N router. Everything is working well (two laptops wirelessly and two TiVo adapters wired), except for my hardwired HP LaserJet 2420dn printer (which worked fine with my old wireless-G router). The router is correctly reading the MAC address of the printer, but the printer is "unable to sense net number".
  • jimfill Jul 18, 2009
    In both cases (with old wireless-G router and with new wireless-N router) I was/am connecting the printer to the router by Ethernet cable, not wirelessly.
    I have copied and pasted your questions and interspersed replies marked by ***.
    1. Where and when does the error "unable to sense net number" appear?
    *** when I use the printer's menu to print a configuration page, on the second page of output after "Status:" under the heading "IPX/SPX"
    2. Which operating system are you using on the computer?
    *** I'm using Mac OS 10.5.7 (Leopard).
    3. Do you know if the IP address of the router has changed? For example, the old router's IP address may have been 192.168.1.1, and the new router's IP address might be 192.168.0.1. Let me know if this is the case.
    *** The old router's address was 192.168.1.1. (It is no longer connected to anything in any way.) The new router's address is again 192.168.1.1.
    4. Do you know what the IP address of the printer is?
    *** Yes. Athttp://192.168.1.1/dhcp_list.stm I can see that the printer's MAC address is correctly recorded and that the printer has been assigned the IP address 192.168.1.110 .
    Regards
    nLinked
    ********** P.S. I have a question. I had intended to sign up for the $19.99 immediate assistance chat, but apparently I accidentally signed up for the $9.99 PER MONTH "unlimited expert assistance". It is quite clear to me that I will not want to continue the service beyond one month. Would you please steer me to where I will need to go and/or what I will need to do to terminate the service after one month?
Hi there
Are you trying to connect the printer to the router by a network cable or wirelessly? And how was it connected previously with the wireless-G router? Please confirm.
Thanks
nLinked
Posted on Jul 18, 2009
  • Anonymous Jul 18, 2009
    Thank you for your reply. I will require some more information to get a better picture of the configuration.
    Regards
    nLinked
I want to get the TIVO AG0100 wireless adapter. I do not have wifi in my house so will it still work? I'm not planning on getting wireless for my computer.
Dear,
Since it's an adapter and not a router, it will not work if you don't have a previously installed wireless network.
You might buy a wireless router and connect it to your computer and use Tivo at the same time.
Jul 22, 2011 | Tivo AG0100 Wireless G USB Network Adapter
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
How to connect Tivo to WRT160N router wirelessly
you need to go to tivos website and see what "wireless usb adapters" are available for your unit.They range between 40 to 80 dollars each if your tivo is wireless compatible
Nov 06, 2009 | Linksys WRT160N Wireless Router
Wireless network
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Jul 17, 2008 | Linksys Wireless-G Broadband Router
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
TiVo/Linksys Compatability
The router should be fine.
Use a Compatible Wired or Wireless adapter.
Jun 19, 2008 | Tivo Series 2 80-Hours Video Recorder
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
