Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Tank not collecting dirty water
First time I'm using the adapter for the upholstery cleaner and
water is coming out of the hand held device but its not collecting
the dirty water in the tank and then the machine just turned off and won't turn back on.
Thank you,
    Sniper:
  • 84 Answers
You most likely have a break in your suction hose. check at the base where it attaches. When you bring back the handle release, you can see lt. If you have the type that has the external plug in for the water, then you probably don't have the hose part plugged in to the collection tank. in the front of the collection tank. Your motor shut off? Well, If you have the first variety cleaner w/built in hose, you may have sucked water into/onto your motor. If this is the case you need to bring it for service. otherwise, you could have a blockage in your collection hose, this would also explain the machine shut down, from the thermosat. A clogged machine will ultimately overheat, wont run again till cooled.
Posted on Jul 18, 2009
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
I have a Hoover SpinVac SpinScrub machine and have used it seven times. The last time I used the machine to clean my carpets, it would not **** up the dirty water. I clean it out each time I use it, but...
The most common reason for lack of pick-up is that the lid is not fully seated on the dirty water tank. Be sure to hook it in front before latching it in the rear. Another common issue is that the duct is missing from the front of the lower tank. The duct is removed to install the attachment hose, and must be put back in place before trying to clean carpeting. It is a square plastic piece - about the size of a slice of bread - which slides in and out of the dirty water tank.
Feb 21, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Why is there no water collection in the dirty water holder?
First make sure the unit is dispensing water, if so then check to make sure the lis on the lower tank is snapped on properly and that the front duct panel is installed. the front panel duct MUST be installed for floor operation to extract the solution from the floor.
May 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Machine will not vacuum up the water
Could be a few things
Look for suction at the head. Turn it on and cover the opening with your hand. You should feel suction. If not something is plugging it or one of the following.
You can usually see a clog as the cover is clear. Fish it out with the tool that came with the machine or fine a wire etc to do the job.
When you put the hand held cleaner in place you remove an insert from the front of the machine. This insert must go back when you change to the main carpet cleaner function.
It could be the lid on the dirty water tank is not on properly or is warped. This will cause a suction leak. If it is warped you can fix it with care. Use a heat source such as a blow torch just enough to soften the plastic and then bend it back into shape with pliers (it's too hot to touch). Be very careful with the heat to just soften the plastic enough to bend.
Adrian
Mar 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Not Sucking the dirty water
It seems that when you emptied the recovery tank it has not been placed back proper.
please make sure it is sealed else you will loose suction
Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steam cleaner
One thing to check is the filter on the inside of the dirty water tank. It must have a 1/4 in. gap from the top to the top of the filter. Also make sure that the lid to the dirty water tank is on and sealing all the way around the tank.
Jan 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hose Attachment
On the clean / dirty water tank there is a red lint lint filter, this is on the upper part of the tank,
If this is blocked it reduces the suction ,this must be free from debris,
If you are using the turbo brush ,
there is a sliding switch on the brush, This diverts the suction from the brush to the nozzle of the attachment ,
You should see the dirty water traveling up the hose ,
You should only use bissells own cleaning solution as using another product would null your guarantee
Jun 11, 2007 | Bissell 9400 ProHeat Upright Wet/Dry...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
195 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
