Need to find a water drain panel for my Ruud ac central cooling 939A
  • 614 Answers
Go online and have your model and serial number ready. Google air conditioning parts and go to any web site. You can even google Ruud ac parts and find what you need. Rus
Posted on Jul 18, 2009
Ruud central ac, what does the flashing snow flakes on the panel mean?
That it is calling for cooling. It should stop blinking when it comes on.
Aug 20, 2014 | Heating & Cooling
Ruud furnance/ac central air
i can help u but mikep858 i need u to give me the model of this ac okay the correct one
best regards
Aug 14, 2008 | Ruud Central System Air Conditioner
My Ruud ac is not cooling
Have you replaced your relay capacitor?
Sep 03, 2012 | Ruud Heating & Cooling
All my other AC Units have had a drain directly to the sewer system...usually connected under a sink. Does my Ruud unit only have the drain to the outside of the house? Usually, when the AC is draining...
If you have a CENTRAL air unit, you should have an overflow to a drain in the furnace area. So I don't understand what you are saying about a connection to the drain under the sink!
Do you have the make and model correctly listed? Because with your question it does not agree what I know about the Ruud Central air that you listed.
Aug 08, 2011 | Ruud UBHC Air Conditioner
My Ruud AC unit compresssor is creating a lot of condensation and home is not properly cooling.
check ur coils are they dirty how is your filter on hot days it will condensate alot however a unit is desighned to opperate for an average of around 87 degree day and may need the superheat adjusted. check and make sure the bigger line coming off that unit is very cold hold your hand over the outdoor fan is the heat off it very warm
Sep 11, 2010 | Ruud Central System Air Conditioner
No power... reset outside on ac unit, checked to see if the water was not draining "clear", the digital display not showing anything
Check the 2 wire that runs from inside unit to outdoor unit for damage. Then check the indoor unit for a circuit board with a blown fuse. If no display it means no 24 v is going from heater to thermostat
May 12, 2010 | Ruud Central System Air Conditioner
Locating Ruud Central Air drain pan?? Water has started dripping through the ceiling from the Ruud Central Air Unit...can't find drain pan?
the drain pan is physically inside the indoor unit.
grab a 1/4" nutdriver and open the bottom service panel your coil and drain pan is there, you won't be able to remove the coil properly but you could see if the system is overflowing causing your flooding problem, let me know what you find
Jun 22, 2009 | Heating & Cooling
A/c unit leaking underneath onto floor, puddle in the hall!
from the evaporator coil, the drain maybe clog. clean the unit to fix it.
Jun 11, 2009 | Ruud Central System Air Conditioner
Ho to turn on central AC unit? (Ruud High Efficiency)
This is typical wiring for a 4 wire thermostat
R = Red One Side of 24 volt Transformer
G = Green Blower relay
Y = Yellow Cool Condensing unit
W = White Heat Furnace
Apr 28, 2009 | Ruud Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
