Question about Vizio L37 Television
How to trun on close caption or cc on 42in vizio??
How to trun on cc on my 42in vizio?? please help fast.
  • 14 Answers
SOURCE: I can not get closed captioning on my vizio VO42L
If you are using a HD cable box then this would be setup in the cable box itself.
Example:
With a Motorola Cable box, you would turn it off and press the menu button (with the receiver off and TV on). This will bring up a menu that will allow you to adjust your digital closed caption settings.
If you do not have a Motorola cable box that I would refer to the manual or call the cable company.
Posted on Apr 05, 2009
SOURCE: Closed caption wont turn off
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
Posted on Jan 05, 2009
SOURCE: My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
Posted on Jan 10, 2009
SOURCE: We can not get CC Closed Captioning to turn off.
had a power outage and it said to reset the clock I went some where and changed the close caption from off to on. It was a in a set up menu
Posted on Jun 11, 2009
leethedeuce
  • 4472 Answers
SOURCE: vizio closed caption
Do you have a cable box hooked up to the unit? On the tv it is quite easy. The directions are located on .48of the manual. Here is an exert it from it is located here:
http://vizio.com/documents/downloads/hdtv/VL420M/254User_Manual.pdf
Thank you,
Lee
Posted on Mar 04, 2010
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
Netflix closed captioning
cant find the closed captioned for Netflix on tv not on computer.
for on the computer, it has C.C on TV
Jan 03, 2014 | Vizio Vbr334 3d Blu-ray Player With Wifi,...
How to closed caption on mute vizio
Hello -
The remote control for your Vizio TV probably has a Closed Caption button. Is there a button with CC printed on it? If so, that is most likely the button to press for Closed Captioning.
Dec 23, 2017 | Vizio 42 in. LCD TV
My closed caption is on and I can't turn it off. I don'want the writing on the screen
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
Oct 24, 2011 | Vizio L37 Television
My Vizio VA19L 19'' LCD Television's closed captioning isn't working. The closed caption isn't on the settings menu either. How can I get closed captioning on?
Just press the CC button on the remote. Some TV stations may not send out CC data. Pressing the CC button many times will cycle thru all the options including OFF.
Mar 05, 2011 | Vizio VA19LHDTV10T 19 in. LCD TV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
I cannot access the closed caption feature on my Vizio VO42L help?
Look at the remote control: (page 14 of the user manual)
CC
/Stop – This button will select the Closed Caption mode. The
options are OFF, CC1, CC2, CC3, CC4, TEXT1, TEXT2, TEXT3 OR
TEXT4. Additionally, this button stops the CD, DVD or VCR when the
component is activated with the remote control.
Download user manual here:
http://tv.manualsonline.com/manuals/mfg/vizio/gv42l.html
Please post back what you find.
Nov 15, 2009 | Vizio GV42L 42 in. LCD Television
Close caption problem
Use ur remote turn off CC functions on the remote.
Or go to the menu go to the caption turn everything off like Text or CC1 CC2.
Sep 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
How to select Texting
I just got my Vizio 32" a few days ago, so this is fresh in my mind. When the tv is on and TV is selected from the top row of remote buttons, press MENU. Use the arrow keys surrounding the MENU button to select the WRENCH icon. Under this icon use the down arrow (surrounding MENU) to select CC. Use the right arrow to choose CC ON MUTE (closed captioning only when you select the MUTE button on remote) or CC where you can use the arrow key to change OFF to ON and closed captioning will be on all the time. Hope this helps!
Sep 28, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L37 Television Logo
941 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
