Computers & Internet Logo
Frank Cee Posted on Sep 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I check a Sanyo tv adapter ?
How do I check if AC current is being converted to DC?
richie46
Level 3:
Top Expert:
  • Computers & ... Master 12,962 Answers
  • Posted on Sep 29, 2016
richie46
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2942800
Points
58151
Use a voltmeter to confirm the presence of stated dc voltage.
4 Related Answers
Anonymous
  • 181 Answers
  • Posted on Feb 09, 2008
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Anonymous
  • 1027 Answers
  • Posted on Apr 19, 2008
SOURCE: AC/DC adapter
Make sure the voltage and amperage is the same and the tip fits.
I use I-GO universal from Radio shack
A
Anonymous
SOURCE: Toshiba laptop battery or AC/DC adapter
Audio codecs
Anonymous
  • 7 Answers
  • Posted on Aug 09, 2012
SOURCE: My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
Power adapter i can us
What does a power adapter do?
An AC adapter, AC/DC adapter, or AC/DC converter is a type of external power supply, often enclosed in a case similar to an AC plug. ... AC adapters are used with electrical devices that require power but do not contain internal components to derive the required voltage and power from mains power.
OR
power adapter. A power supply for electronic devices. Also called an "AC adapter" or "charger," power adapters plug into a wall outlet and convert AC to a single DC voltage. Computers use multiple DC voltages, and the power adapter is the external part of the power supply for a laptop.
https://www.pcmag.com/encyclopedia/term/power-adapter
How do I use this adapter in the US with 220 voltage
is it an 220volt ac - dc adapter you could buy a 110V AC to DC adapter with the same DC Voltage and current rating
or you could buy a 110V to 220 Volt adapter
http://www.banggood.com/110V-to-220V-and-220V-to-110V-Voltage-Transformer-Converter-100W-p-938645.html?currency=AUD&refreshTmp=1&utm_source=google&utm_medium=shopping&utm_content=lola&utm_campaign=Beauty-AU&gclid=CIG68_Gl2cICFVcJvAod7GgArw
be careful with switch settings
http://www.ebay.com/bhp/transformer-110v-to-220v
please be aware if timing is required or electrical motors this could be a problem as usa is 60Hz and your appliciance may be designed to run at 50 Hz frequency
there are devices that can convert freq from 60hz to 50 hz
https://www.youtube.com/watch?v=RV3hEKLNm74
http://www.frequencyinverter.org/
Dec 22, 2014 • Photography
2answers
How can I operate my LG 26LE5300 LED LCD TV in my motorhome the most direct way possible (i.e....without an inverter)? This low power (40-50 watts) TV has an external brick to convert 120 AC to it's...
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
3helpful
My Sanyo TV just quit working one day after a bad electical storm Its a Model number CLT2054 with an external 12 volt AC to DC converter cord. I thought it may be the converter and replaced it via the...
Did you bought your replacement AC Adapter on Ebay. well I bought mine on Ebay as well but you know what they're not the exact replacement. I encountered a problem with mine, because of the reverse polarity on the output power. you can fix this though, cut the output wire leading to your TV then connect the white wire with the un-shielded one and to the same on the other wire.
1helpful
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
16helpful
2answers
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Looking for ac dc adapter for my Sanyo flat panel tv
It periodically goes dead and needs a firm slap in the palm of my hand to get it to come to life again. Unit runs fairly warm so wonder if it is a safety problem.
Grand Canyon Tech
Grand Canyon Tech
