Question about Motorola Mobility MOTO W755 Cellular Phone
Cell phone got a bit wet and is on standalone mode and none of the buttons will work ro change it except the power button, can I reset the whole phone somehow?
How to reset my samsung galaxy j1 ace
1. power off your device
2. In the next step press and hold together: Volume Up + Home + Power key for a couple of seconds
3. You should release held keys when the Samsung Logo appears on the screen.
4. After that, select from Recovery Mode menu "wipe data / factory reset" using Volume buttons to navigate and Power button to confirm
5. Choose "Yes -- delete all user data" to confirm the whole operation
6. Then select option "reboot system now".
Now your phone will reboot a bit longer then usual, but that's normal.
Aug 04, 2017 | Samsung Cell Phones
Restore factory default setting samsung GT-19305
Warning! All data will be lost after hard reset.Please make backup first.
1.Power off your phone
2.Press together volume up + home button + power button until you will se Samsung logo on the screen
3.Select with volume buttons "wipe data/factory reset" and press power button to confirm
4.Select "yes" and press power button to confirm
5.Wait until format is complete
7.Press power to confirm "reboot"
8.Wait until the phone restarts
That's it!
- See more at: http://factory-reset.blogspot.ro/2013/11/samsung-galaxy-s3-4g-i9305-hard-reset.html#sthash.IRpj0Oyt.dpuf
Aug 15, 2014 | Samsung Cell Phones
How to install stock rom on blu dash jr d140?
hardrest sir if will done!!!
check diz one
If You Can't Boot
If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
  • Nexus 7: Volume Up + Volume Down + Power
  • Samsung Galaxy S3: Volume Up + Home + Power
  • Motorola Droid X: Home + Power
  • Devices With Camera Buttons: Volume Up + Camera
Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen.
Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its factory state and all your data will be erased.
If your device freezes at any point, hold down the Power button until it restarts.
If You Can Boot
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3.
Tap the Factory data reset option and to through the reset of the steps to confirm the factory reset.
If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
(There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
goodluck
Jun 22, 2014 | Blu Dash Jr D140 Cell Phone
Need to master reset
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
  • Volume Up + Home + Power
  • Volume Down + Power
  • Home + Power
  • If none of the above work, do a web search for your phone's model plus "recovery mode".
  • 3-
  • Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
  • You will be asked to confirm the factory reset.
  • 4--
    Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
    • thank u!
Apr 05, 2014 | Samsung Galaxy S 4G Cell Phone
Only the power button works
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Jul 25, 2012 | Samsung SCH-u740 Cellular Phone
I forgot my onlock pattern..and google account password also
There are 2 solutions: 1. is to enter your google username (try just username and if not working add username@gmail.com) and in password field to enter number 0 that is number ZERO.
2. If other is not working you will have to reset to factory settings your phone, loosing all your data except on SD card.
For resetting your phone to factory settings you will have to enter recovery mode. Here are the steps: First try to enter Recovery Mode. There are a few ways to enter in Recovery Mode -> video link.Once in a recovery you can easily choose Factory Reset. On upper link you can find three ways to do it, and one way of doing it goes like this, it usually works:
1. Power Off your phone2. Press and hold Volume Up button + Power button + Home Menu button (just hold all three buttons at same time until logo appears)3. Select Wipe all data / Factory Reset (you select it with Volume Up and Volume Down buttons and execute it with Power button or in some cases with Home Menu button).
If you watch videos you will find same thing.
Jul 26, 2011 | Samsung Galaxy S GTI9000 Smartphone
Forgot gmail to unlock phone
If your phone is locked because of too many patterns entered then ...
Jul 25, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have a sony ericsson t303. none of the buttons work
my sister has this phone try taking off buttons and clean them
Jul 23, 2009 | Motorola Mobility RAZR V3
Key pad won't respond
first of all change your internal keypad
if not works
please change your keypad ic
for more information
you can mail me
raj_the_great2008@yahoo.com
thanks
Mar 18, 2008 | LG CU500 Cellular Phone
The buttons on my phone won't work
what you should do first is have the firmware on the phone reflash , then if that does not work then you can buy a new phone.
Nov 08, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility MOTO W755 Cellular Phone Logo
121 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
