Question about HP Officejet 9110 All-In-One InkJet Printer
I have an HP 9110 and recently had a paper jam. Followed all of the jam solution steps, removed the paper and reinstalled parts as directed. The ADF jam warning won't go away. Reboot the printer, still ADF warning. What to do?
    Sniper:
  • 80 Answers
I know that this answer is almost 3 years late, but I had this problem today and hopefully this may help others.
After realizing that there really wasn't a paper jam, something else had to be causing the problem. That meant a switch or sensor or something. After looking all over both the auto duplex feeder and the rest of the paper path, I found a little sensor about the size of a nickle under the bar that the printer heads slide back and forth on. It appeared to be loose and misaligned. From above, I was able to snap that sensor back into place, and that error went away.
I believe that the cause of the sensor being knocked off in the first place was the fact my wife was printing duplex on card stock. The sensor is there to determine where the end of the paper is so that it can feed backward. Card stock, being, well, stockier, probably knocked it around a bit.
Since this sensor also determines when the paper has passed so that it can send the next sheet through, when misaligned (or knocked off its base) the paper never actually finishes the path and doesn't drop into the tray. The sensor still sees the paper and thinks that there is a jam (even though this isn't in the duplex part of the printer, the printer can't imagine why any other part of the feed would be jammed, so it blames it on the duplex feeder).
Posted on May 11, 2012
    President:
  • 3,085 Answers
Pull up the document feeder door to open and make sure there are no obstructions in the feeder.
Posted on Jul 19, 2009
MY HP OGGICEJET 8610/8620/8630 KEEP ON JAM
These steps at the official HP site should help you thoroughly troubleshoot removing the cause of a paper jam with your specific model.
An ADF Paper Jam Error Displays on the HP Officejet Pro 8610 8620 8630...
Dec 06, 2016 | HP Office Equipment & Supplies
Epson wf 3540 paper jam in adf and the mechanical system keeps on grinding in there. Is there a video somewhere on how to open the ADF and align parts in there. I know how to open the adf from the sid
please try the below link all the steps to be followed carefully.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=FAQ&oid=232591&foid=254073
Jan 17, 2015 | Epson WorkForce WF-3540 Wireless...
How to clear adf paper jam?
adf is the top part of the printer from where you feed the paper for copying. adf is automatic document feeder. open the top cover and see if there is any paper in it, remove the paper and close it again and it will reset the paper jam.if it doesn't reset then there could be a small piece of paper stuck somewhere.
Jan 06, 2011 | HP LaserJet M1522nf Multifunction Printer...
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
I had a paper jam and I took the back off and this
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printer says there is a paper jam but there isn't
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
HP Officejet 9110 All-In-One InkJet Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
