Question about Operating Systems
Game Embedded In Excel 2007 Won't Play
I received an email with an excel attachment. The excel spreadsheet contained one of those embedded games. I am running Windows Vista and Office 2007. I am not able to play this game. None of the links are active (I cannot click on "Play", etc). I've enabled macros but the problem persists. How do I get around this so that I can play the game?
Thnx for your help.
Re: Game Embedded In Excel 2007 Won't Play
There will be a small tab on the game above which asks you to enable the content. click on the yellow box and ckick on enable content. you'll be able to play the game
Posted on May 07, 2009
  • 58 Answers
You are better off not playing the game as they usually contain some form of malware.
To possibly infect yourself you by playing the game will need to change the security settings for macros in excel. This is usually located in the Tools menu. Set it for the least restrictive setting, but you have been warned, you will be infected with malware. If not with this game then in the near future.
Posted on Nov 20, 2007
0 characters
3 Points
Why does Polaris Office 5 app close when I click on the excel tab to open a file?
First step is to go to settings then apps, select Polaris app and then touch "clear data" and "clear cache". Next check to see if your app is working correctly, if not, uninstall and then reinstall the app. If it is a paid for app, Google play store will know, also doing an uninstall and install should not delete any saved files you have created previously.
Hope this helps
Mar 31, 2015 | Google Android
I need to open excel in spreadsheet
Excel itself is a spreadsheet - You have to install Microsoft Office with Excel to read & edit the Excel files.
If you just want to view the excel you can download Free Excel Viewer & install on your System @
You can download & install which is free @ to view & edit your Excel files.
Hope it helps.
Apr 14, 2011 | Microsoft Windows Vista Home Premium with...
Who invented microsoft excel/
Excel is a spreadsheet developed by Microsoft but is by no means the first spreadsheet.
The very first spreadsheet was developed (or invented) by Dan Bricklin and Bob Frankston called VisiCalc. VisiCalc was a spreadsheet written to operate on the Apple II computer and was released in 1979. The program was sold to Lotus who developed Lotus 123 from the VisiCalc principle. Lotus 123 was released in 1983.
Excel, first released in 1987, is a development of the early spreadsheets and therefore cannot strictly be classified as an invention. Excel is far more powerful than VisiCalc but that is also a result of development over the years that Microsoft have been working on the product, and the increase in computing power.
Dan Bricklin and Bob Frankston never patented the product because software patents were almost unheard of in the 70s.
Apr 11, 2011 | Microsoft Operating Systems
How to open excel sheet in different window?
While one spreadsheet is open in Excel, open the second spreadsheet as follows:
Go to Start, Programs, Excel (or however you navigate to Excel). Then in the new Excel window select FILE, OPEN, then your 2nd spreadsheet.
Mar 29, 2011 | Microsoft Windows XP Professional
When using Mail Merge, how can you make Word 2007 ignore any Blank cells in Excel 2007?
  • Open the Microsoft Excel 2007 spreadsheet file on your computer that contains the blank cells that you want to merge.
  • 2
    Use your mouse to select the adjacent blank cells that you want to merge together. The cells you want to merge should then be highlighted in blue.
  • 3
    Click on the "Home" tab and then click on the "Merge and Center" option from the "Alignment" group. The blank cells will all be merged and centered.
  • 4
    Click on the arrow next to the "Merge and Center" option and then click on the "Merge Across" option if you don't want the blank cells centered.
  • 5
    Select the merged cells and then click on the "Merge and Center" button again at any time to split the cells.
  • Mar 07, 2011 | Operating Systems
    How to freeze columns and rows on excel?
    To freeze columns and rows in Excel, here's what you need to do:
    - Excel 2003 & older: To do this, open your Excel spreadsheet. Select the cell that is below the left-most column heading that you wish to see. Then under the Window menu, select Freeze Panes.
    - Excel 2007 & newer: Click on the View tab, and then on Freeze Panes. In here you have 3 options, first one does exactly the same thing as the one from older versions, second one freezes the top row and the last one freezes the first column.
    Dec 02, 2010 | Microsoft Operating Systems
    I have Microsoft Office 2007 which I purchased from Dell and installed late last year or earlier this year, however, the Excel keeps getting lost and I cannot open documents which I have done or received...
    Use to find the serial number. As for the corrupt Excel program, you may need to determine what exactly is the problem there.
    Go to Start, All Programs, Microsoft Office and see if Excel is listed. If it is, then click on it to launch it. Does it open? If so, then go to where your excel spreadsheets are saved to (e.g. My Documents) then right click an Excel spreadsheet & click on "Open With". Select Choose Program. Select the Microsoft Excel. If Excel is not listed, click the browse button and browse to C:\Program Files\Microsoft Office\Office12. Click the Always use the selected program to open this type of file checkbox. Click OK
    Nov 26, 2010 | Microsoft Windows XP Professional
    Solution for Excel 2003 "the file is not in a recognizable format"
    If you open an excel created by M/S Office 2007, Excel 2003 will not be able the file. You have to install Microsoft Office the "Compatibility Pack for Word, Excel, and PowerPoint File Formats" for M/S Office 2003 from Microsoft Site.
    Your Excel file is corrupt!
    Hope it helps.
    Oct 01, 2010 | Operating Systems
    Excel file corrupt how to recover
    If you are using Office 2007, there's compatibility software offered by microsoft, otherwise try a data recovery software.. sodeep
    Aug 20, 2009 | Microsoft Windows XP Home Edition with...
    Excel 2007: number formatting
    Let me give you some basic info first. Information within a cell is discreet. You can add to it...the $ sign as an example...with functions (actual code which equals a program) embedded in Excel or you can type it in.....but you would have to create an actual program to do what you would like to do.
    I don't use your version of Excel but I am extremely confident you cannot do what you would like to do. Sorry....Tango.
    Feb 08, 2008 | Operating Systems
    Operating Systems Logo
    3,082 people viewed this question
    Top Operating Systems Experts
    Brian Sullivan
    Brian Sullivan
    Are you an Operating System Expert? Answer questions, earn points and help others
