Question about Frigidaire FWS833A Top Load Washer
Have a Frigidaire washer, model# FWSB6600FS0. Have leveled feet, adjusted water levels to the load of clothes, yet it still starts dancing in spin cycle. Any other clues to check?
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
  • 1294 Answers
SOURCE: BACK LEG LEVELING ARM
The back legs are usually not adjustable. Adjust the front legs & lock them with the lock nuts, at the lowest level, that is the machine tilts towards the front. Adjust further if there is any shake when you try with your hands.
You could also check to see if any springs or shocks have become loose. Refer manual.
Posted on Mar 30, 2008
  • 126 Answers
SOURCE: vibrating on spin cycle.
If the machine is new there is a possibility that the shipping pin didn't come out completely. If you set the machine up yourself, there is a yellow plastic strap that holds in the electric plug. You need to pull, not cut this plastic strap as it has a pin that is about 8-10" long that goes through under the tub to secure the machine for shipping.
Posted on Jan 20, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
Clothing stuck in washer machine
Is it stuck in the center agitator or the out tub?
Jul 04, 2008 | Washing Machines
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Wahser jumps around during spin cycle
rking9847
If your machine model is an FAV6800A or FAV9800A the issue could be a Clutch malfunction.
Does the Spin cycle error out with unbalance errors such as dC or uC if your machine is one of the above machine models?
If so see this post Clutch Fix for a step by step to Clutch maintenance or replacement if necessary.
Post back if you have additional concerns with your FAV6800A or FAV9800A.
Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
SPINNING OUT OF CONTROL MACHINE IS DANCING ACROSS THE FLOOR
You need to adjust the legs on the bottom to get it balanced so it does not spin and cause it to bounce. fill a clear glass of water up to 1/8 inch of top place on machine on the side and then the front observe if unit is level if not adjust till level from right to left and front to back. spin outthe adusting feet on the bottom of the washer.
Jun 14, 2009 | Samsung WF337AA Front Load Washer
Washing machine dances all over at high speed spin.
Push down on each corner, one at a time, when you push on a corner and the dancing stops, that's the corner that needs balance. adjust the foot.
Jun 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
While spinning my Neptune will dance all over the floor sometimes
Dear gpotts839, Friday 2-20-2009 11:27pm EST (USA)
Underneath the washer on each corner are leveling legs that are probably not level. They are adjustable so make sure the washer is level by trying to shake it when off and adjusting the legs, with pliers or by hand, so it won't rock at all when off.
If this isn't your problem it may be from overloading the washer with clothes or a large comforter or not using enough water when filling.
jack
Feb 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
