Question about Refrigerators
Both freezer and refrigerator will not cool to proper temps. ice build up on the freezer back wall.
  • Mike Smith
    Mike Smith May 11, 2010
    What brand and model number ?
  • Mike Smith
    What is model number ?
  • Refrigerators Master
  • 1,606 Answers
Check the freezer fan .If working , then you have a defrost problem .Would need make and model number .
Posted on Jul 19, 2009
Freezer not cooling properly
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
My 13 y ear old Lieherr in France has Snowy Frost buildup on the back top half of the interior wall, but the temperature in the fridge even at 7 is only 10 degrees C and will not get colder. The freezer...
Hello and Welcome to FixYa!
Since you have quoted that you have already vacuumed the condenser unit from the back and had already removed all dust & lint from the condenser unit so that possibility should be ruled out. The Poor cooling that you are facing could also be (In fact the most common reason) due to the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing/opening the panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer that is exactly the thing you quoted. Such a frost build-up usually shows a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed/designed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (usually a bi-metallic switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. If the problem still persists and the above quoted techniques/tips didn't work,You may need a qualified appliance repair technician to further diagnose the problem.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Liebherr European Right Hinge Fully...
Freezer seems to be working properly, but fridge cant keep temp
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 25, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Not cooling enough
I had the same problem and I discovered it was the defrost element that was shorted out which keeps the ice from building up located behind the back freezer wall.
Aug 09, 2009 | Refrigerators
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana (freezer on top) not making ice; fridge warm
I would be calling the store from where it was purchased it should be under warranty. If the ice maker is not working the freezer is not getting down to proper temp. therefor the refrigerator does not cool because all cooling takes place in the freezer, there is a damper between the refrigerator and freezer that allows air through cooling the refrigeration section. Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap.coil is icing up and there is no air blowing into the refrigerator. This is the most common problem.
Oct 20, 2008 | Amana ATB1836AR Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
