Question about HP LaserJet 3050 All-In-One Printer
Paper jam, status reflects no paper pick up press check mark, but nothing will happen.
    President:
  • HP Master
  • 1,447 Answers
You must be change your printer cartridge or cartridge chip reset.
May you you reffill your cartridge
Posted on Sep 17, 2009
  • Sazeed Computer
    Sazeed Computer Sep 18, 2009
    Your printer paper feed sensor liver is broken or displace please check it, install position
  • Sazeed Computer
    Sazeed Computer Sep 27, 2009
    ofcourse you change your printer cartridge
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
It is sying i have a paper jam but there is no paper in it
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Dec 12, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Paper Jam
this is probably the sensor inside the transfer sheet or the reflection plate under the cleaning blade assy being dirty. also there is a reflection plate on the bottom of the transfer sheet near the gear assy
Sep 16, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon pc 720
Check if you have any matter that is blocking the paper path, also try to clean the rollers that picks up paper. If you happened that copier is in a dusty enviroment, dust could deposit on rollers, and rollers when picking up paper will start slipping. Try to clean with alcohol.
Jul 04, 2008 | Office Equipment & Supplies
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
What paper jam?
Does the printer even try to pick a piece of paper from the supply tray? If not, then it would appear that a sensor somewhere in the paper path is bad, either mechanically or electronically. Often, these sensors have a lever which touches the paper. If by chance the lever is broken or stuck it won't give a correct message to the logic circuit. If by chance the sensor is electronically defective, it would still give a bad message to the logic, and it would need to be replaced. Logic circuitry could be bad, in which case, replace the printer. With the lowcost printer/all-in-one units these days, it seems fixya has a continual flow of inquiries. Maybe this will give you some help.
Aug 08, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
