CD player reads only some cds or only spins. - Audio Players & Recorders
    Problem Solver:
  • 18 Answers
First thing to do is to clean the lens on the pickup. Use camera or Eyeglasses lens cleaner that is safe on plastics. If that doesnt help then it may be either your spindle height is wrong or the focus is off. Both of these should be checked by a tech. Sometimes as laser pickup get older they go out of adjustment. There are usually pots on the main board for track error and focus and a few other parameters. There are also sometimes pots on the pickup itself. I wouldnt recommend adjusting these yourself but if you do it anyway, mark them with a magic marker for thier original position so you can return to it if the adjustment doesnt help. You make a tiny adjustment and try a disc....then repeat. Small adjustments are all thats needed!!! If you arn't sure what your doing dont touch it. Service personel use an oscilloscope and a test disc with voltage measurements to properly do the adjustments.
Posted on Jul 23, 2009
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Cd player says no rdy
Everything was working fine it reading the CDs playing music then one of the CDs jammed after that everything worked except the CDs were not spinning and it now says no rdy wtf can be wrong
Jan 19, 2013 | Emerson MS9700 CD Shelf System
Cd player is not working. One day it was working and next day it wasn't. I guess a button was pushed and now we can't figure out. Cd player will not read or play cds
?: Does the cd spins? If it does the optical eye that reads the cd could be dirty. Clean the eye with cd lens cleaner. If the cd is not spinning the motor could be bad. Also some cd players can't read certain disks because of the density of the disk. Make sure you read the manual to see what cds are compatible with your boombox. I hope these solutions were helpful.
Good Luck
George
Mar 01, 2009 | RCA Audio Players & Recorders
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
Sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
Jun 03, 2008 | Audio Players & Recorders
Doesn't Play Some CDs
hi, you have to know that a burned CD have a life limited around 10 years and after to read these CDs you have to make a new copy of them. :(
Mar 31, 2008 | Alpine CDM-7833
Error 2 on Display
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside... if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser.. ampman!
Sep 05, 2007 | Sanyo ECD-T1550 CD Player
145 people viewed this question
 Grubhead
Grubhead
