Question about Traxxas E-maxx Evx-2 Monster Truck
TraxxasE Maxx how do you rebuld Slip clutch looks easy .Do you replace pads or replace hole thing ? Ican see how to ajust the clutch when your done but how do you know when it right ? do you ajust tell the plats just touch the shoes or what .Thank for any help. Mike
    Scholar:
  • 66 Answers
For a slipper clutch you replace the pads
for motors clutch you replace the pads and springs
and for the brake you replace the pads unless disc is no longer smooth/pads missing then replace disc too
slipper clutch adjustment, hold the vehicle stationary and turn the spur gear by hand, it should turn if not then loosen nut on slipper, if too easy then tighten...............drive to fine tune......it should slip if stopped at full throttle to prevent spur/clutch gear damage
Posted on Oct 03, 2009
My car is a toyota carib.. and the clutch is slipping any way of ajust ing to stop it slipping .. I can drive up road fine and if I excellerate then it starts to Rev up and then the gear catches up
Hi, No, unfortunately you will have to pull the transmission to replace the clutch disc. It could be contaminated with oil or just worn out.
This is not an easy thing to do if you're not mechanically inclined.
Go and have it done by a qualified mechanic. Good luck.
May 28, 2015 | Toyota Cars & Trucks
How do I replace the clutch cable on a 2003 Kia Rio?
they are really easy to do the end just goes into a little hole then it just goes agains the stop inside the hole they are really easy to do , look on youtube you may find your answer there
Jan 19, 2015 | 2003 Kia Rio
How to remove and replace Tata Indica gearbox
not a bad little car i think,done one last year for a new clutch and i it was that easy that i honestly do not remember having any problems with it ,only one tip i will offer though and i do this on all motors and thats to drill a hole in the bellhousing with a hole cutter big enough to get a 10mm socket 1/4 drive through the hole to tighten the clutch bolts ,getting to old to struggle now so i make a hle that aligns up with the clutch bolts then fit bolts holding the clutch finger tight then once the box goes in nice and easy as the clutch plate can move a bit then two big bell housing bolts in and then rotate the flywheel twic tightening the bolts one by one .easy better than hurting ones back with a struggle
Apr 13, 2012 | Tata Indica Cars & Trucks
My 1992 Honda Accord cluth is starting to slip,opon acceleration.Is there any way to tighten the clutch,or prolong replaceing the clutch right now.
the only thing that you can do is just be easy on it and avoid fast accelaration ..the less you allow it to slip the longer you can prolong it ..so just baby it for now
Feb 21, 2011 | 1992 Honda Accord
Clutch slippage
Drain fluid out of clutch cylinder. Clean out cylinder then look at bottom and you will see 2 small holes.Stick a small pin or wire into the hole that has a little check ball inside. Once you can push that ball in with the pin you will see some fluid come into the reservoir. That lets you know it was clogged. Now refill with dot 4 and bleed system. Clutch will not slip now. I just had the same problem and changed clutch spring, plates, etc and nothing worked until I did this.
May 24, 2010 | 1996 kawasaki VN 1500 Vulcan Classic
Hi, I have 2002 Legacy L wagon. The clutch is engaging/disengaging very high. Can I adjust it back down?
Sorry your problem is easy ...all you need is a complete new clutch assy .
As the clutch is a self adjusting unit and the only thing that causes it is either you use it like a hotrod and slip the clutch when powering up OR rideing the clutch when on hills or at the lights,,,or the car has done a lot of miles..
But if the clutch drives 1/2 from the top then replace the lot dont replace just centre plate you want the
complete Kit
Oct 04, 2009 | Subaru Legacy Cars & Trucks
The clutch started slipping. is there a way to ajust it. what would cause it to slip if it not ajustable. it only has 14995 miles. the fluid was low. i filled it
Ah yes! The missing clue! You put more stuff in the gearbox. But what exactly did you put in it? Motorcycle engines do not do well using synthetic oil, or oils with "special" additives or "friction reducers". Drain whatever is in the gearbox and refill with 10w40 motor oil. Shell, Mobil, Quaker State. Any major brand will do. It may require a one hour ride and a second oil change to rid the gearbox of the synthetic. Clutch plates that swell are usually toast. Plates that just slip usually recover after awhile. Install a new oil filter. Look it up in the manual. See below.
A “very helpful” rating on this answer? Thanks!
Jul 04, 2009 | 2004 Suzuki VS 800 Intruder
Replace pads on 04 malbu maxx namely the left rear
i used good old shade tree machanic knowdledge backed up and punted. got my old c-clamp and just turn the hell out of it and it relessed and i was able to put the calper back on and finish in no time but i do thank you.
Nov 22, 2008 | 2006 Chevrolet Malibu Maxx
Traxxas E-maxx Evx-2 Monster Truck Logo
593 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
