The tv itself makes a high pitched sound when I turn it on, but there is no audio to the tv. I checked all the cords, mute button is off, I plugged in other devices and a surround sound system and still no luck. I'm wondering what the issue could possibly be, as i'd like to try to repair it myself if I can
Here are the most common reasons you may not have sound.
Starting with the most common solutions for no sound from TV:
Television Has No Sound Answer 1: Make sure TV is not muted.
Television Has No Sound Answer 2: Make sure the TV is not set to SAP (secondary audio protocol)
Television Has No Sound Answer 3: Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)
Television Has No Sound Answer 4: Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.
Television Has No Sound Answer 5: Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)
Television Has No Sound Answer 6: If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.
Television Has No Sound Answer 7: Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.
Testimonial: "I already went through all of that- i'm looking to speculate what next? what could it possibly be that's faulty?"
