Question about Panasonic SC-HT940 System
F-61 error Weird.......mine works until my dish goes out due to storms. Then I get this message. My brother fixed it once, but doesn't remember what he did!
  • 158 Answers
F61 IS A PROTECTION FAULT.POSSIBLY YOUR FAN OR AUDIO STAGE IS FAULTY
Posted on Aug 03, 2009
Satellite internet losing service during storm
I just got satellite internet service a few months ago and it has been going OK until there was a thunderstorm last night and more rain today. The internet has not been working very well, coming in and out in spurts. I got my dish from Calera at http://www.calera.biz. Does anyone know how to fix their dishes specifically and figure out how to make the internet work better? Spray TEFLON coating on dish
Dec 27, 2013 | Computers & Internet
After storm, my keyboard is not working . So i use my brother's keyboard and test whether it is still work or not . But it also doesn't work, so whats wrong with my computer ? Can any kind person...
It seems that you may have lost connection to the keyboard inside the machine or it could be the plug itself. Most of the ones i couldnt fix went online and got the on screen keyboard. Its a bit unusual to use but it buys time until u get a new computer or find someone local to check the internal connections.
Nov 05, 2012 | Computers & Internet
Dishlex dx303 error message 50
Our Electrolux DX303 had an i50 error. It was due to a water leak causing earth leakage current. So it's good it stops working if it detects a leak.
Our leak was from where the water goes to the upper arm (the pipe is made of plastic and has a plastic thread which isn't strong ie cheap). The pipe is located on the back right hand side once you take off the panels.
Apr 15, 2012 | Dishwashers
Black ink doesn't print - no error message. All others work fine. Already have clean it (several times)
You need to call Brother at 1-877-BROTHER and tell them your machine is not printing black. Brother is covering the cost to repair this problem ( replacing printhead) on certain models, so try calling Brother and you may get it fixed for free.
Jun 02, 2011 | Brother MFC-290C Printer
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
I have Dish Network and I can't find a Code for my LG RC797T so I can get it to play
I'm assuming you are referring to using the dish network remote to control your DVD/VCR unit. Use the instructions in your Dish Network manual, mine is on page 61, "Setting up using device code tables". Refer to the table of device codes in the back of the dish manual, pg 119, to look up your manufacturer. I used the DVD codes for LG as LG wasn't listed on DVD/VCR combo codes. Try each one until one works. I have the LG RC797T and the third code worked 824. Good luck!
Mar 31, 2010 | LG RC797T
Error message on Brother SE-270D
I had the same issue a few years back but with actual symptoms of malfunctioning. I had mine fixed under warranty. The service tech told me it was a faulty circuit board. Works perfect now. I think the warranty is only for the first year to cover labor and parts. Not sure how much it would be out-of-pocket. This happened within 3 months of a brand new purchase. Hope this answered your question.
Mar 16, 2009 | Brother SE-270D Computerized Sewing...
Won't print
This indicates that the fuser req' replacement but it can also be
a mpcb fault.
If the problem occured during a flash storm i would go for the
mpcb.
mongrelken.
May 21, 2008 | Brother HL-2040 Laser Printer
Trouble with Tuner 2
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
May 14, 2008 | Samsung SIRS4120R Receiver
Panasonic SC-HT940 System Logo
489 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
