Question about Home
I get a high pitch buzzing noise when showers on when i turn cold water tap on it stops
  • 297 Answers
What you have is called air hammer. you can have this fixed by putting on an in line airator on the hot side near the shower,a good plumber will do this for you.
Posted on Jul 24, 2009
Hear whistling noise whenever hot water is used180
mostly the high pitched noise is the rapid vibration of the tap washer
it indicates a faulty washer
a local plumber can replace the washers and diagnose any other problem
Jul 19, 2016 | Home
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I have a mira duo shower why does it make a high pitched squeal when in use the shower is onley 3 months old and has done this from new
Hi Derek
I trust you are well
Sounds like it might be a air bubble in the waer pipes, try removing the shower head and run the hot and cold water together for a minute, then remember to FIRST TURN OFF THE HOT WATER then turn off the cold water and replace the shower head and test as normal.
Hope this helps
Kind regards
Aug 15, 2014 | Home
The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Jul 11, 2010 | Price Pfister R897EBK Brushed Nickel...
I have a shower unit running from my bath taps the cold water pressure is high so i cannot get the right temp. is there a thermostatic .control valve i can fit to the shower pipe outlet
there is an ajustment on most tub and shower valves, remove handle and there is a plastic peice that stops the handle from turning to the hot side to much. try to adjust. you shouldnt have to shut water off to house, but to be safe you might want to.
Oct 28, 2009 | Home
SHower noise
Loose washer in hot or cold tap. Replace or tighten.
Sep 10, 2009 | Water Pik Shower Head
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Home Logo
658 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
