Question about Kenmore Washing Machines
Has a bad odor when is empty - Kenmore Washing Machines
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hi eventually loads of washing machines have this problem, check and clean the outlet in your ubend under sink and clean all outlets, after pop your machine on a quick empty wash cycle, also changing from power to simple gels and liquid will help with less residue build ups.
Posted on Jul 19, 2009
How do i get the odor out
run a wash cycle empty after putting a full gallon of white vinegar in it.. you can also run a full cycle with CLR In it, but it is harsher than vinegar.
Jun 25, 2014 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Water remains in hose and smells
Front loaders are known for bad odors. Run an empty cycle with double bleach and let the machine totally dry out, with the door OPEN. The bleach will kill the mold spores and letting it dry out will prevent more from forming.
Dec 19, 2012 | GE Wh12x10309 Heater for Adora Front Load...
My sub zero ice smells bad like fish how di I remove and clean?
My ice maker smells like bad fish too! Emptied everything out. Cleaned every part, placed baking soda inside to absorb odors, but still stinks! Why? What more can I do?
Mar 07, 2011 | Sub-Zero 632 / S
What is the proper way to store an empty chest (deep) freezer for several months?
I would suggest wadding up about enough newspapers , to completely cover the bottom of the freezer . The ink in the newspaper , will absorb any odor that is in the freezer or can get in , while being stored . This is also , the only way known in the area , to remove fish , or bad meat odor . Takes a little more newspaper for that though .
Oct 14, 2009 | Whirlpool Freezers
Ventless gas log odor
kINDLY HELP WITH a description of this odor. If it is setting off your smoke alarm the flame or combustion is not complete or thorough.Are these new loggs or previously used without problem?Is the flue open on the chimney? The venting is apparently very poor if at all and the house is fulling with fumes. Turn the gas off, Open up the house to clear the air and check the flue, making sure it is open. Be safe.Ned
Oct 07, 2009 | Heating & Cooling
Bad Smell
Try cleaning the filter screen in the bottom and under it as food particles get caught in and under it and rot. Afterward run an empty load with two cups of vinegar.
Sep 22, 2009 | KitchenAid Dishwashers
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
