Question about Hotpoint Aquarius WMA42 Front Load Washer
Where do i put washing powder in hotpoint aquarius 1000 three compartments in drawer what solutions go in what compartment
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
With experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Posted on Jul 18, 2009
Washing powder compartment fills up with water
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
Jul 13, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius WM32. Will no longer use the conditioner from the dispenser drawer. dapchiles@talktalk.net
There is probably a blockage in the drawer.
Remove drawer and thoroughly clean all parts, making sure there is no residue of powder or conditioner in any of the compartments.
Nov 20, 2010 | Hotpoint Washing Machines
Why is the washing powder not washing away? insteard it stays in the drawer and clumps together.
It either needs to be thoroughly cleaned, or there is a blockage in the dispenser compartment.
Remove drawer and clean all parts, remove and poke with a piece of wire the little blue plastic piece, sometimes grey, this hopefully will solve the problem.
Mar 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint
Check level of machine as may be leaning slightly forward. Use front feet to adjust to level or slightly lifted at the front. This will compensate for any slight buckle in the plastics on the drawer compartment.
Feb 07, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Can this machine heat its own water? It has a hot and cold water intake. also mashing machine is not taking the powder from the powder drawer. Can you help?
Yes, this washer does have a heating element.
Make sure there is a good water pressure at the inlet valve/s,
or the powder will not dispense.
Make sure there is no blockage or obstruction in the drawer, \also make sure you have the powader in the correct compartment.
Hope this helps.
Dec 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Where ecxactly do you put washing powder and stasoft
Washing powder should go in the right hand side compartment, if it is not going down, then check that water is coming into washer.
Conditioner should go in the smallest of the compartments.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
1,189 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
