Question about Dryers
Dryer does not heat up. Power and element are ok.
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Posted on Jul 19, 2009
Tip
Electric dryer will not heat?
If the electric dryer does not heat at all then there are some possibilities that have to be checked to confirm the fault.
1)check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not heating is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) The other possibility if the power is ok and if the thermal fuse is ok. Then the problem can be due to fault in the heating element. The heating element looks like a long coil of special wire. You can check heating elements continuity with an ohm meter. If there is no continuity that means the element is bad and you need to replace it. The heating elements cannot be repaired it should be replaced if faulty.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get proper power and will not work Due to partial power.
This will help. Thanks.
on Mar 23, 2010 | Dryers
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
Roper model rex5634kq1----won't get hot---already removed &ck'd heating element & attached part (thermostat?)--they're both ok--what else could it be?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Dryers
Heating element not working on a ele ctric dryer
With the power disconnected you can check the resistance of the heating element. Remove the back of the dryer. Remove the connectors to the element and if the resistance measured is any greater than 25 Ohms then the element will need replacing. If the element is OK then check the thermal fuse(s) or thermistor on top of the housing which are there to present overheating. That’s really all there is to it if the motor is running and the timer id working OK.
Oct 30, 2009 | Whirlpool Dryers
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
Dryer not heating...everything seems OK
Y'ou are zeroing in on your problem. Read the info below and hopefully you will have your answer:
Heating element
Thermal fuse
Wiring
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Condenser Dryer turns but no heat
Check with multi-meter for power on the heating element's tags (115/220V). If it does get power,you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Aug 21, 2006 | AEG T57800 Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
