Question about Hotpoint Aquarius WMA42 Front Load Washer
Where do i put washing powder 3 compartments in drawer one 2 the right one to the left smaller one in middle at front what solutions go where
Worked it 0uy dont e mail again
Posted on Jul 19, 2009
Hi. I have a 2nd hand WD8016C LG but dont know which compartment is pre wash, wash + fabric softener. Also, bubbles form at the window and stay at the end Thankyou
First compartment on right side of drawer is prewash, next to it on the left is wash, second compartment on right is softener. Bubbles because you are using far too much detergent. Only use 2 tablespoons max for normal fairly large wash load, even less for smaller loads. Front loaders use little water, so need much less detergent. Also, highly suggest you not use softener, leaves residue in washer that soon turns to mildew and bad odors. Use white vinegar in its place. Helps remove detergent residue from clothes, keeps tub smelling good, and is very inexpensive. Liquid detergent is also an issue--it too leaves residue behind. Powdered detergent works much better and also is cheaper(counterintuitive you would think liquid dissolves better, but it doesn't).
Dec 16, 2016 | LG Washing Machines
I've been given this machine, there are 3 compartments in the detergent drawer but don't know which one is which!
there will be a small compartment with a flower on, this is for softener, and a large and small one will make up the remainders. The karge one is for your wash powder / detergent and the smaller of the 2 forr pre-wash treatments
Apr 11, 2014 | Whirlpool Washing Machines
I have just bought a second hand front loader which compartment do I put wasdhing powder in and what are the other two compartments
Hi from retired Englishman in SW France @14:24 Wed afternoon,
I am presuming you do not have a manual- most manuals can be obtained on-line. I think there is an advert somewhere on this site! No! No commission!
3 compartments - pre-wash powder, wash powder and finally conditioner/softener. As you do not say what make and model yours is we will 'cheat' a bit to find out which is which!
If you pull the drawer out just enough to be able to see into it, then put the machine on pre-wash for a few seconds you should be able to see into which compartment the water is running! Do the same with the main wash. You are then left with the conditioner one which, when you look at the whole drawer, one looks distinctly different from the other 2. With our Bosch it is in the middle but with our daughter's (can't remember which make it is!) the conditioner tray is on the right.
John C
Feb 02, 2011 | Washing Machines
In which of the 3 compartments should I put a liquid soap?
The small centre rack is used for whitening agent! The extreme right for the pre wash.
For delicates you have to use the same rack and finish the load. See to it there are no remains of powder, if your load is delicate material.
Apr 02, 2010 | Siemens WD61392GB Front Load Washer /...
What holes
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
Jul 27, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Where do i put washing powder in hotpoint aquarius 1000 three compartments in drawer what solutions go in what compartment
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Soap
As you look at the despenser drawer it has 3 chambers. The left chamber is for Prewash detergent, middle for Fabric conditioner, right is for Liquid or powder detergent. Or use a plastic ball in the main drum!
May 05, 2008 | Hotpoint Ultima WD72 Front Load...
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
