How to resolve the problem with psd file?
When I try to open a psd Photoshop file, an error message Photoshop experienced an error trying to open the file. occurs, and the file couldn't be opened properly. How can i open corrupted photoshop file?
    New Friend:
  • 4 Answers
There are many reasons that cause this error. you can prefer to use good PSD file repair software. PSD Open File Tool - is the best option to fix all Photoshop file errors
Here the link: https://www.openfiletool.com/psdopen.html
Posted on Oct 06, 2016
Testimonial: "thank you very much."
    Master:
  • 124 Answers
The PSD file mainly created by Photoshop tool, as per my advice you can try to open your corrupted or heavily damaged PSD file with different Photoshop version because it can be happen your PSD file is not completely corrupted, may be any chance to view your PSD file if this technique not work then I personally recommend a third party tool I give you a link where you can download free psd viewer tool and you can open and convert you PSD file by this link.
http://www.freeviewer.org/psd/
Thank You
Posted on Oct 15, 2016
    Master:
  • 531 Answers
If the file is corrupted, there's nothing you can do short of finding another copy of the file.
Posted on Sep 27, 2016
Testimonial: "Very pity"
  • The Vanguardian
    The Vanguardian Oct 03, 2016
    There are a few companies that have a good chance of rebuilding files like that, but they are VERY expensive. They work on failed files when a business desperately needs them. They charge hundreds per hour.
  • 119 Answers
SOURCE: problem with adobe photoshop cs2
this happens a lot with the "portable" version and it sometimes happens when you have cracked it
if neither is your case it may be possible something deleted the info from your registry, just reinstall the program to solve it
Posted on Dec 14, 2007
lenny297
  • 133 Answers
SOURCE: Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Posted on Mar 14, 2008
SOURCE: Photoshop 7.0
Um, using a 5 year old program on a brand new OS, and having it not work is NOT Apple's fault. You didn't have to upgrade to Leopard. That was your choice, and you should have done your research before doing so it it meant that much to you.
However, you can upgrade to CS3 from 7 (much cheaper) if you want. Otherwise, don't install Leopard, simple as that. No one screwed anyone, you did it to yourself. My goodness, asking one company to maintain support for another company's 5 year old program instead of making necessary upgrades is very very silly.
Good luck.
Posted on Jul 10, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Posted on Oct 28, 2008
  • 9 Answers
SOURCE: referenced memory error in photoshop elements 6
Was it the preferences file that you deleted? The description you gave to your problem sounds like your running a windows machine instead of Mac so i'll give you keys for PC. While program is launching hold down the following keys "Control+Shift+Alt" then when there is a screen that asks to delete the prefs files select "yes".
Posted on Dec 07, 2008
.psd file in photoshop 18.0
Ultimate solution which might more effective than all listed is photoshop repair corrupted file
It is helpful tip
This one artilce from Adobe, is also can assist you
· Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
· Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
· Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name.
Photoshop Repair Toolbox Solve Adobe Photoshop problems and issues by keeping it up to date https://helpx.adobe.com/photoshop/kb/file-recovery-photoshop.html
Aug 17, 2017 | Computers & Internet
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
Sep 16, 2015 | Adobe Photoshop CS for PC
Psd corrupted!!? (Layers Gone)
I don't think I've ever seen a PSD file corrupted on disk myself. Often it's a sign of system instability. Did you have a crash or power failure while it was saving (keeping in mind that it may appear to finish before it's actually all the way saved to disk)?
Are your disk hardware and file system healthy? Look in your event logs for any indications of failures.
Try some repair tool:
PSD Repair Kit is the ultimate Adobe PSD repair tool that is a must-have for any digital artist, photographer or other professional working with numerous PSD files.
For more information: http://www.psd.repair/
If it doesnt work, try to look at the answer here:http://www.filerepairforum.com/forum/adobe/adobe-aa/photoshop/590-restoring-a-corrupted-psd-file
Dec 02, 2014 | Adobe Photoshop Elements 6: Windows
Unable open PSD: "unexpected end of file" error
1. Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
2. Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click
3. Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
4. Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name.
You may find all these actions on next source:
http://www.filerepairforum.com/forum/adobe/adobe-aa/photoshop/324-%E2%80%8Bis-there-any-way-to-recover-a-corrupt-psd-file
Or if all these solutions can't help you, make use of Recovery Toolbox for Photoshop
Refer link: http://www.photoshop.recoverytoolbox.com/
Oct 13, 2014 | Adobe Computers & Internet
A message comes up when I try to open a file in Gimp, when I haven't had issues opening it previously.
You may repair .psd files with the aid of
fix corrupt psd file
program can't modifying your original .psd file data during restoration
Feb 17, 2012 | GIMP GNU Image Manipulation Program
Adobe Photoshop CS3 program will not open PSD files on CD
Do you update your widnows at all? If you did then you do a system restore and not install that update for windows
Feb 06, 2009 | Adobe Computers & Internet
Can't save .psd file
The .psd format will open only in Photoshop . Try saving a new file and reopening it if you still face the same problem then you need to reinstall Photoshop
Dec 15, 2008 | Adobe Photoshop 7.0 for PC
Photoshop CS3 Error
I've never heard of this, unless the user is saving to a PDF format. Have you tried saving a Photoshop document in a different format? Photoshop files are: PSD's or PDD's. I have only ever seen 'presets' in PDF format. In CS3, these are set by selecting: Edit> Adobe PDF Presets.
Apr 23, 2008 | Adobe Computers & Internet
Can't save my psd file
search and destroy / modify the file 'editing.xml' in your 'application data' directory.
it will be in your %temp%\..\..\Application Data\Adobe\Workflow
(if ur operating is win 2000 / xp)
have a nice day
bye
Jan 15, 2008 | Adobe Photoshop 7.0 (321115627)
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
