Question about Kenmore 98702 Stacked Washer/Dryer
I need a manual
I need a wiring diagram for this and for the outlet
My cigarette lighter has never been hooked up when purchased new i need to hook it up for charging purposes
Can you read the diagram? I haven't looked at your owners manual fuse boxes to see if you have cigar relay? Either way should work, In the diagram, the orange wire is voltage, black wire is ground for both the cigar lighter and/or auxiliary power outlet. Note the fuses.
Mar 12, 2017 | Buick Cars & Trucks
I need wiring diagram for Amana AKT3650E. I have 220VAC supply without a neutral. Electricain says the warning lights need 115VAC. How it that achieved?
So the manual:
http://media.datatail.com/docs/specs/164433_en.pdf
says the power requirements are 120/240 VAC 3 wire single phase.
Almost all wiring includes a ground wire, so saying 3 wire also says it additionally has a ground wire. However, many oven outlets were wired using the neutral as the ground (now considered illegal - especially for new installations) - so they had a 3 prong plug.
Metering from any 2 holes (at a time) in the receptacle should reveal 240 V (across the similar slots) and 120 V and 120 V (from outside slots to middle slot).
have a look at this thread
Installing 3 prong outlet for new range Family Handyman DIY Home Forum
Feb 24, 2015 | Amana Kitchen Ranges
Exploded view of ignition system
Online sites have wiring diagams available for download. Auto parts outlets have manuals covering wiring diagrams. Obtain a shop manual for the vehicle. Libraries also may have shop manuals available for loan. Hope this helps you. PS try wiring diagrams .com
Nov 29, 2014 | Hyundai Motor 1996 Elantra
Some of the 110 outlets in my 1999 Damon Intruder read hot and ground reversed. the outlets used to work but no longer for what ever reason. Why may that be? And would a wiring diagram help me? Could
Your question is a little hard to decipher!
By "110 outlets" I assume you mean 110V AC Power Points.
By "read hot" I would guess that you mean an Active or Hot AC Voltage where it shouldn't be and not Red Hot.
If that is the case then you need to have an electrician test the power point outlets before someone gets an electric shock.
If you are unsure of whats what then a diagram aint going to help!
Sorry.... But Safety First
Dealing with electrical problems at these voltages can be lethal.
Now.... if you have an ohm meter you can check the wiring with the power off and yes.... a diagram would be helpful.... even for the electrician
Cheers
....Jack
Sep 15, 2014 | RVs
Need wiring diagram for a 1974 Fleetwood Glenbrock mobile home
FIXYA DOESN'T HAVE ANY WIRING DIAGRAMS, SORRY.
Jul 09, 2012 | Cars & Trucks
Does my 2007 focus titanium have more than 1 power output source?
According to the wiring diagrams, you vehicle is only equipped with one (1) Cigar Lighter/Power Outlet. Usually, the wiring diagrams will show others as possible options if they are available from the manufacturer. There are no optional additional power outlets on the diagrams I have.
However, power outlets are available at most aftermarket parts stores...You could install an additional one if you have a need for another one.
Apr 24, 2011 | 2007 Ford Focus (3 Door) Hatchback
Plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Dec 25, 2009 | Electrical Supplies
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
[email protected]
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 98702 Stacked Washer/Dryer Logo
93 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
