Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
Furnance fire and only heats for 20 seconds and
Furnace fires but only heats for 20 seconds and then shuts down. Changing other components didn't fix it. Changing control bord fixed problem. can the board be repaired?
  • 128 Answers
No.
Posted on Aug 23, 2009
My oil furnance is running but when it reches temperature it shuts off and will not come back on until we bleed the lines
You have a small leak on the suction side of the pump between the tank and the pump. when this happens the pump looses prime each time the furnace shuts down and when the furnace tries to fire up again the saftey device trips before the oil gets to the burner.
Jan 25, 2015 | Heating & Cooling
Furnance blows out cold air
Your problem is listed under Air Conditioners--
So is your furnace gas fired, oil fired-- or possibly a Heat pump?
Heat pumps have a hard time getting any heat from outside, when it is bitter cold out-- could that be a clue?
If you have gas-- Does your furnace have a standing pilot?-- if so, when was the Thermocouple last changed?
If it has a glow ignitor-- is the ignitor glowing brightly on start up?
If oil, do you have both oil and spark-- right at the nozzle tip-
Please tell us more, so we can help you more.
Mack B
Jan 23, 2011 | Heating & Cooling
Furnance kicks on but will only heat to about 13- 14 degrees then kicks off.... this happened last year and it was the flame sensor so it could be that again if so where is the flame sensor located? or...
usually if the flame sensor is dirty, the burners will light and then go out after about 3-4 seconds. it sounds like your furnace is staying lit for quit awhile and i would not suspect a flame sensor. I would look more at an air flow issue. if the furnace it running long enough to warm the house up 13-14 degrees. i would check the air filter to see if it may be dirty or even if you have a large enough opening for the filter to allow good air flow. you could have a situation were you are either not getting enough air to the furnace, or not being able to get rid of the heat being generated and causing the furnace to shut off on high limit. normally if a furnace shuts off on high limit, the fan will continue to run until it cools down and then it will fire back up. this may continue a few times. sometimes if a furnace trips on high limit too many times, it will lock out for a few hours before trying to light again. I would make sure you have plenty of air getting to the furnace and make sure all the supplies are open and not blocked. is this a problem that just started. did you just purchase the house and it has always worked this way. any information regarding the history of the unit would help narrow down the problem. also if the unit has a/c on it, it may have a dirty coil that is restricting air flow.
Nov 19, 2010 | Heating & Cooling
Furnace fires up then shuts right back down
Hi check out the pressure switch ,see if it it blocked / jump it out and see if it lights ,by jumping it out you can fool it into fireing up,on some models
Feb 28, 2010 | Goodman GMS90703BXA Heater
My heater turns on the gas starts but then it shuts down
Try to locate the red and white wires either behind your thermostat or on the furnace itself. Jump them out and see if the furnace stays on. If you do it at the furnace you will need to hold the door switch down. If it runs fine, you have found your problem (the thermostat) if it goes out again, the furnace will display a number of blinks on the circuit board. Look on the reverse side of the furnace access door and there should be an Error Code chart to get you started figuring where to look next.
Nov 10, 2008 | Goodman GMS90703BXA Heater
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
163 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
