Question about Foxconn NF4SLI7AA-8KRS2 LGA775/NF4 C19/DDR2/SATA2/ (814227018614) Motherboard
NF4SLI7AA-8KRS2 boots with 250gig WD HDD. SLI card in Normal Mode configuration on motherboard. Using ATI PowerColor X800GTO 256MB DDR3 in PCIE x16 Slot nearest to cpu. Scrambled Video output. no onboard vga video port available. does not recognize PCI slot video card.
    Sergeant:
  • 449 Answers
Go to the BIOS Setup and change the VGA setting from ON BOARD AGPP to PCI. Then use option SAVE and EXIT. (ehteshamhusain@gmail.com)
Posted on Jul 19, 2009
I have gigabyte m68mt-s2p mother board can i install amd radeon hd6670 2gb ddr3 graphic card on my mother board
The Radeon HD6670 should work in the PCI-e x16 2.0 slot. The 2.1 card is backwards compatible with the 2.0 slot.
The only problem could be your case configuration (you need about 8.8" of clearance). You also will need to check if your power supply gives enough power to run the card and the other components. AMD recommends a 400W continuous output power supply for a single HD6670 card.
I hope this helps.
Aug 06, 2012 | Gigabyte GV-R667D3-1GI AMD Radeon HD 6670...
Something wrong with SLI
If you are using two SLI card they need to be bridged together so that the GPUs work together to process the load. Also, in your BIOS you must make sure you configure it to use SLI. Furthermore, the most important thing is that if you are using SLI cards that you update the graphics softeware and set the cards to be bridged. SLI is flaky sometimes, just have to iron out the behavior and tweak it over time and make sure that everyting is clocked right.
May 27, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I need help choosing a video card.
Hi there.
Any PCI Express card will do as long as its DDR2, DDR3 is not supported by your motherboard.
You have a choice between ATI or Nvidia graphics cards and your system should support up to 1GB of graphics memory.
Good luck and thanks for using FixYa!!
May 13, 2009 | Intel D101GGC Motherboard
Asus m2n sli deluxe sli 1 is 16 and 2 is 8 how to work 8 8
THIS MAY BE THREE WAYS ONE IS THREW THE BOIS
AND
JUMPERS ON THE MOTHERBOARD
VEDIO CARD
AND
SOFTWARE DRIVEN FOR THE MOTHERBOARD AND VEDIO CARD
THE MONITOR TOO [DRIVERS]
PROPERTIES, ADVANCE SETTINGS
IF YOU NEED MORE INFO PLEASE CONTACT THREW THE WEB SITE
ROD
Feb 05, 2009 | ASUS M2N-SLI Deluxe Motherboard
PCI
"As of 2007, PCI Express has replaced AGP as the most common interface for graphics cards on new systems. With a few exceptions, all graphics cards being released today (2008) from ATI and NVIDIA use PCI Express. NVIDIA uses the high bandwidth data transfer of PCIe for its newly developed Scalable Link Interface (SLI) technology, which allows two graphics cards of the same chipset and model number to be run as a pair, allowing increased performance. ATI also has developed a dual-GPU system based on PCIe called CrossFire. Towards the end of 2007, AMD released a motherboard chipset, the AMD 790FX, which supports up to four PCIe x16 slots, allowing tri-GPU and quad-GPU configurations for ATI cards.
Uptake for other forms of PC expansion has been much slower and PCI remains dominant. PCI Express is commonly used for onboard gigabit ethernet and wi-fi but add-in cards are still generally PCI, particularly at the lower end of the market. Sound cards, modems, serial port cards and other cards with low-speed interfaces are still nearly all PCI. For this reason most motherboards supporting PCI Express offer legacy PCI slots as well."
Source/Link: WikiPedia
Please let me know if this helps. Good luck!
Feb 28, 2008 | Televison & Video
Computer does not boot up
Remove the second card. There is a few other things that must be done before you can select SLI & run.
Go to page 4-26 of your manual. You must set primary display adapter to PCI-E within the bios
Page 4.24 section: 4.4.4 set to AUTO. Section 4.4.5 set to High Preformance. Make sure your connecting your PCIE card in the 2 blue x16 slots & not the white x8 PCIE slot, found on page 2-20.
Happy computing & please vote.
Jan 12, 2008 | ASUS P5N32-E SLI PLUS (0610839148967)...
Foxconn NF4SLI7AA-8KRS2 LGA775/NF4 C19/DDR2/SATA2/ (814227018614) Motherboard Logo
111 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
