Question about Curtis DVD1047 DVD Player
Connection to my old TV
I have a new DVD player with a 3 pin connector (video, audio right, audio left). I want to connect it to my old TV (tube) having only an input to a cable (there is no 3 pin connector)
Is there an adapter for that?
    President:
  • 632 Answers
Your tv do not have an audio/video input...what you need is a device called RF modulator, it converts the audio/video signal from your dvd player into RF signal similar to the signal from the cable operator.it has an audio/video input and a coaxial cable output..
Posted on Jul 18, 2009
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
How to connect player to a tv with no hdmi port
The old fashioned way ofcourse. Use the three pin RC lead. The one which has a red, white and yellow connectors on each end. yellow is video, red and white are for each audio channel.. Left and Right.
Aug 13, 2014 | Sony BDP-S3200 blu-ray/DVD player with...
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
I bought a used Integra DVD player without any cables hooked to it. How many cables do I need and where do I plug them in?
The most basic connection is the 3 wire RCA cables with the Yellow, Red, and White ends, that connect the VIDEO, AUDIO LEFT and AUDIO RIGHT from the DVD player to the TV.
Plug the 3 cables into the corresponding colors on the VIDEO OUT and AUDIO OUT connectors on the back of the DVD player.
Then plug the other ends of the cable into the corresponding VIDEO IN and AUDIO IN connectors on the back of your TV.
The yellow cable is always the VIDEO signal and the red / white are the AUDIO left and right.
Then to watch the DVD player on your TV, just switch the TV's INPUT MODE SELECTOR option to VIDEO 1 or whatever label your TV has for the rear inputs.
That should be it.
There are other ways to connect the two devices, but that is the simplest and cheapest.
Thank you and good luck.
Apr 19, 2011 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Can't get anything to show on TV screen..No menu or anything..
I'm still confused. Walmart has this with pictures. This DVD player has regular RF Coaxial TV output and input. But, the best way to connect it would be Video Out and Audio Out for the connection from the DVD Player to the TV. I guess it has a tuner in it? or else why would it have a TV input on a DVD player?
Specifically the Pr, Pb, and Y connectors and the Red and White - Left and Right Audio Out connectors.
That would give you the best audio and video to most modern TV for last couple of years. (I don't see HDMI but that would be even better if it had that.)
So does your TV not have Component Video (Pr Pb Y) inputs? And Audio Left/Right inputs?
If not then you are connecting Coaxial Cable RF input to your tv? The TV would have to be in TV mode in this case and on the correct channel ... I would imagin Channel 3 or 4 of the old NTSC style TV channels. Most TV's still do those - even with the new Digital TV channels being active.
Nov 22, 2009 | iLO DVDR05 DVD Recorder
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
What cords do you need to hook up the panisonic DMR-E75V DVD/ VCR Combo?
hook to a what? direct to your TV or to an audio/video amp? That depends on what is available in your DVD/VCR or toy our TV. simple cnnection is just the composite video signal colored yellow RCA connector. Video out of your DVD/VCD to Video input of your TV. Another option maybe if it has which is better is S-Video output of DVD to S-Video input TV. if you;re doing it via audio/video amp, then simply look for the input source and connect your video there. The audio... it's also RCD connectors colored Red/White for your right/left channels. it will always be like that for a stereo amp setup. but if you are using audio.video amp with sound preocessing then you'll have more audio connections at least 5, mains left/right, surround channels left/right, your center speaker, your subwoofer.
Apr 06, 2008 | Televison & Video
Need Help Setting Up DVD player to an old Zenith Television
You can find the owner's manual for this set online at: http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd It says that the BOTTOM four connectors are: 1. S-Video IN 2. Video IN 3. Audio (Right) IN 4. Audio (Left) IN Above the Audio IN connectors are two audio OUT connectors, which you could hook to external speakers, your stereo, etc. But these are not needed for hooking up your DVD player. From your DVD player, you need to hook up either the S-Video or Video connection (Video is typically the Yellow wire), plus the Audio connections (Red and White). If your DVD player has an S-Video output, this will give you a better picture than the standard Video connection. S-Video cables have a different plug, with four or five wires in the connector, and are keyed so they only fit into the socket in one orientation. Be careful to line it up properly and not force it in the wrong way.
Feb 28, 2007 | Zenith B25A74R 25" TV
Curtis DVD1047 DVD Player Logo
211 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
