Question about Acer X193W LCD Monitor
Monitor says no signal
Monitor will power up then it says no signal ....
  • 59 Answers
Connect the monitor to another computer and see if works. I think the monitor it is ok, your computer have a problem.
Posted on Jul 18, 2009
  • Acer Master
  • 3,866 Answers
Sometime the pins on the connecter get bent check and see if that is what is going on then unbend them with a paper clip or a needle nose plyers. If there not bent check the computer video card.
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
Replace power supply, computer on, monitor no signal, help
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
May 16, 2010 | E-Machines eMachines Desktop PC
Losing signal to monitor
check all cable, and check you video card that it is seated correctly they can come loose ue to expansion and contraction
May 16, 2009 | Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
17" monitor has power running into it but when you press the power button, speakers crackle but no image on monitor & power LED goes off
see if the signal coming to the monitor is active...
you can check this be disconnecting the rs232 cable from monitor to cpu..
when u disconnect it.it will display the no signal icon on the monitor...else there is some problem with your monitor...
Oct 29, 2008 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
What is the triggering signal to power on the monitor?
Most modern monitors use the Horizontal sync line to determine when to go to standby.
Aug 18, 2006 | BenQ V773 17" CRT Monitor
Acer X193W LCD Monitor Logo
273 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
