Question about Acer 22" X223w LCD Monitor
A pink line the whole height of the monitor has
A pink thin line the whole height of the monitor has appeared almost in the middle of the screen, how do I get rid of it?
Its broke mine went after 2 months return it. Got mine from Tesco, after all their lies wont be buying from them again
Posted on Jul 22, 2009
    Problem Solver:
  • 5 Answers
Try setting you screen size to a larger or lower size. and the pixel color. try 32bit instead of 16bit.
Posted on Jul 21, 2009
Thin pink line is appearing on my brand new dell 15 R inspiron ..Can you please tell me the reason behind thi s.. i bought it from US and moment i openend it , it is showing thin pink line..
Hi, i can help you. plz connect your laptop to an external monitor. if you can see your monitor without problem in that monitor, it should be the problem with the LCD. i think your laptop have an international warranty, plz contact your laptop brand local support team...
thanks & regards
Anas K A
Jul 08, 2011 | Dell Inspiron 9300 Notebook
We have such a monitor when i start pc a thin line apper in the middle in the screen and it is continuous appearing.
Try monitor on another PC, if fixed then video driver is corrupt, if same monitor or cable is faulty.
Oct 19, 2010 | Computers & Internet
I have a thin black line across my screen half way down
You don't say whether it is a LCD monitor or a CRT one.
CRT Trinitron tubes have two thin black lines, one at about 1/3 height, one at about 2/3. This is normal and nothing to be worried about (sometimes one and more rarely both lines can't be seen).
LCD monitors should NOT have any black lines at all, and if they do it's probably a driver latch circuit gone bad -- and there's not much that can be done in practice, except replace the monitor.
Oct 24, 2009 | Soyo Computers & Internet
Pink line down the middle of the screen
Lcb is liquid crystal display and there is liquid and some chemical in it and it cause this problem .or some put some think on it or you drop the lcd . i also have the same issue . If it is under warrenty replace it.
Sep 29, 2009 | Samsung SyncMaster T240 Monitor
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Two light lines have just appeared
Your driver transistors are failing on those "Rows" of Pixels.. a common problem .. you could try "Pixel Reviver" software from here http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor see if that helps.. but it possibly is on the way out sorry..
May 22, 2007 | Sony SDM-HS75/B 17" LCD Monitor
Acer 22" X223w LCD Monitor Logo
289 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
