Question about Nintendo 64 Console
Nintedo 64 stoage box/case/holder
There is a case you can get, well plastic box that you put you n64 in and it has a drawer to put controls in ect. seen one on usa ebay but they wont ship to england. really gotta find one. please help xxx
  • 20 Answers
Re: Nintedo 64 stoage box/case/holder
Is this what you are looking for?
I have one I can ship to you.
Posted on Dec 03, 2007
    Problem Solver:
  • 14 Answers
It would most likely be very expensive shipping.
Posted on Nov 20, 2007
0 characters
3 Points
I bought a new AV cable for my nintendo 64 off ebay and when i plugged it in the brightness of my games were really bright
Well it could be because HDTV was not made the time N64 cameout so you would have to use a blue plug for it to work instead of the traditional av cables.
Jan 19, 2012 | Nintendo 64 Console
I dont know how to set it up
- First you need a rather old TV, like maybe before 2002, if you have one. Because on newer TVs N64 graphics are terrible !
- Once you have your TV, check to see if you have two cables with your 64 (if you don't something is missing !). One shaped like a little box on one end and an electrical plug on the other : you hook up the little box to your N64 and plug the device in the nearest power socket. The other cable has a a strange black and rectangular input that hook up in your N64 and 3 sockets that are red, yellow and white. Connect the latter on your TV by finding the same sockets with the same colours !
- Connect your controller to the console (it's the round-ish sockets in front of it)
- insert your game
- THEN turn on your console. Don't turn it on unless everything hooked up !
(if it doesn't work you may want to try the famous turn-off-the-console-blow-into-the-cartridge-put-it-back-and-try-turning-your-N64-again trick !)
Good luck ! :)
May 28, 2011 | Nintendo 64 Console
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack '
    Nov 17, 2010 | Nintendo 64 Console
    Second Hand N64 seems to be dead...
    first... i recommend u get a new AV connection for it... a nintendo 64 one or a gamecube one.. any one of those should work... and make sure u blow inside the opening where u put in the game and blow in the game too.. that might also be the case..
    Dec 02, 2009 | Nintendo 64 Console
    Awfull graphics with nintendo 64
    I Had An N64 Myself They Are Just An Old Machine Sounds Like Your Graphics Card May Be Shot Or Not Connected Properly, I Recommend You Have It Serviced, When You Take It In Explain The Problem At Hand What It's Doing, How Long Its Been Happening, What You've Tried To Fix It Ect. They May Be Able To Help But Like I Said It's An Old Machine And They May Not Be Able To Help. Hope This Is Of Some Help To You.
    May 11, 2009 | Nintendo 64 Console
    Nintendo 64 Pokemon Stadium Transfer Pak Error
    Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
    Jan 26, 2009 | Nintendo 64 Console
    N64 will not play on new TV and Stereo Reciever
    I bypassed the stereo reciever and plugged the cords into imput 2 in our tv. It works fine.
    Nov 29, 2008 | Nintendo 64 Console
    Great clarification Nisha...
    As with many other problems like this, check the input cable. it could be busted, and need to be replaced. Clean the contacts in the control deck, and in the cartridges.
    Oct 22, 2008 | Nintendo 64 Console
    Nintedo 64
    Considering how shortprint it was and it's popularity, you best shot is on e-Bay. Most N64 owner's aren't really willing to part with CBFD, so it might be pricey.
    Jul 05, 2008 | Nintendo 64 Console
    N64 game Pak
    It's not too hard, remove the "Do not remove" sticker first. Then take a flat head screwdriver and put it in the notch where the cover clicked in on the top and just pop it out. Here is a guide with pictures (although they have the official tool, a screw driver works just fine.)
    Aug 30, 2007 | Nintendo 64 Console
    Nintendo 64 Console Logo
    48 people viewed this question
    Top Nintendo Video Game Consoles Experts
    Troy Gorman
    Troy Gorman
    Paul Layton
    Level 1 Expert
    Are you a Nintendo Video Game Console Expert? Answer questions, earn points and help others
