Question about Sanyo EasyStreet NVM4070 GPS Receiver
Is there anyway to get a bluetooth phone and bt gps to pair if they won't communicate with each other
I have on occasion been able to get my NVM 4070 to connect with my phone. I have tested several different phones with this GPS. I noticed that if you are using a smartphone or pda it has trouble connecting. However, if you try and connect a basic phone, like a Motorola Razr, it has no problem.Overall it is a frustrating process that involves quite a bit of superstitious behavior, on my part, to get the devices to connect. Try restarting both of them.
Once you actually get them to connect, good luck. Like I said, I am able to connect mine, but usually once I leave my car, I have to start the pairing process all over again.
Posted on Aug 13, 2009
Garmin troubleshooting
You need to pair with the gps first before you can use as handsfree. Turn on BT in your iphone and start to pair with the gps, there may be a code showing at the gps screen and then type the code on your phone, then they paired which means you can start to use it. Good luck.
Sep 01, 2014 | Garmin nuvi 2597LMT - GPS receiver
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at support1@digixmedia.com or going to http://www.contelusa.net
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Can't hear people during calls
sounds to me like theirs an issue with the Bluetooth and phones connection possibility. gps usualy has the bluetooth connection to cellphones and other devices. this is near feild technology and several factors can cause issues. example 1. you have a Bluetooth headset turned on and paired with the phone. if this is the case please try to shut the bt headset off and then pair the gps with your phone as per instructions.
another possibility exists that your phone may be getting interfearance from another phone or device on the same frequency band. to test that theory simply turn off any nearby waterless devices if your not sure.
my last thought would be that that your gps unti amy have a mute button or mode. this allows you to stop the other side from hearing your conversation.
as you can see theirs a broad range of things that can affect the near-field signals.
Oct 14, 2012 | GPS
Paring iphone via bluetooth
If your phone is paired, you should be able to listen to music using the BT audio source.
Aug 19, 2012 | Pioneer AVIC-F900BT Car GPS Receiver
Not able to pair my bt-03a with my android device
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Jan 20, 2012 | Genius BT-03A Bluetooth Headset
How to use External Gps?
Most external bluetooth GPS units uses serial ports to communicate to the GPS software. You don't need to bother with the External GPS thingy in the setting page. If u really ask, u need to pair using BT to the GPS unit. Under bluetooth setting, u can create and outgoing port as well. On your GPS software, point it to look at that port number.
Feb 12, 2010 | HTC Touch Viva Cell Phone
Bluetooth setup
You need to pair your phone with your bluetooth headset.
  1. Turn on your phone's bluetooth and search for bluetooth devices.
  2. While the phoneis searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the phone finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Nov 11, 2009 | Radio Communications
Nokia N 73 Bluetooth problem
have you tried selecting bluetooth devices through the satnav software itself or are you trying to pair it through the phone itself?
Sep 01, 2007 | Nokia N73 Cellular Phone
Sanyo EasyStreet NVM4070 GPS Receiver Logo
80 people viewed this question
Top Sanyo GPS Experts
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
