k
kitty van gemert Posted on Sep 27, 2016
Macbook pro to hitachi cp-x2510z not working
I have a vga to hdmi to connect projector to macbook pro. it is not seeing the macbook at all, it keeps searching. via is in computer in1 port
5 Related Answers
Anonymous
  • 563 Answers
  • Posted on Mar 26, 2008
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Anonymous
  • Posted on May 26, 2008
SOURCE: Apple Macbook pro video out to VGA port ("d-sub") on Optoma
There's no solution. it will not connect with macbook pro or any other mac. as on the phone with all technicians and they do not know what to do. I had the unit replaced and still would not connect.
Anonymous
  • 10 Answers
  • Posted on Feb 20, 2009
SOURCE: projector cannot detect my connection to my laptop
try hitting function 8, had the same problem giving a presentation and that took care of it.
Anonymous
  • Posted on Apr 21, 2009
SOURCE: Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
projdoc
jasbo
  • 2239 Answers
  • Posted on Aug 18, 2009
SOURCE: Dell 2400MP out of range with vga connection
make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
Hitachi cp-s318 no input signal, channel chose right, make screen duplicate on laptop. laptop identity as none PnP monitor. No any drivers for projector,
The projector has a RGB input
So to use it on a VGA output from the computer you would need a VGA to RGB adapter
or something like this adapter
https://www.auselectronicsdirect.com.au/hdmi-to-vga-and-rgb-component-converter
with a component cable
as projector has component inputs also
What might be the problem since my macbook pro is connected to the projector through a HDMI to VGA adapter, yet the screen remains black?
Vga and hdmi are different formats. Unless you are using a coverter box that translates the data from one format to another it won't work. Vga is analog and hdmi is digital
1helpful
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
No display
Try a restart with the projector still connected. See if it detects it after a restart.
Having trouble with Y-VGA splitter, connecting to both Dell 380 computer and projector at the same time - Dell monitor cuts off when connected to projector.
Sounds like the the monitor detect line is causing your issue. The Hitachi CP-X250 has VGA in & out. Hook the Dell to the VGA out port of the projector.
2helpful
2answers
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
1helpful
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
4helpful
2answers
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
