Computers & Internet Logo
Djuna Holiday Posted on Sep 27, 2016
I bought a Toshiba Satellite P105-S6084 ON EBAY not realizing that it had a operating system on it called ZORIN 11 . I do not want this operating system on it , I know nothing about it and prefer Windows that it came with. How do I go about putting it back to the way it was with the operating system that came with it? I don't know much about computers or systems or drivers etc , so I am really confused on what to do. Do I have to go out and buy a windows cd or what ?
5 Related Answers
Anonymous
  • 367 Answers
  • Posted on Jan 20, 2009
SOURCE: I have a Toshiba Satellite
Take battery out of the back of laptop, put back in. if that doesnt help:
1.) remove battery from back of latptop
2.) remove cmos battery should be accessable through one of the panels on bottom of latop.
Are you getting any beep codes?
Anonymous
  • 77 Answers
  • Posted on Apr 09, 2010
SOURCE: how to replace RTC battery in Toshiba Satellite
Found a like for you to check as to how to dismantle your Laptop. Hope this helps.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
  • Posted on May 05, 2010
SOURCE: does the toshiba satellite p105 s6084 support ACHI
Yeah it does support ACHI but you have configure it.
Please let me know if you have any further questions or concerns.
Thanks.
Anonymous
  • 1833 Answers
  • Posted on Aug 14, 2011
SOURCE: I have a Toshiba A200
When CD/DVD related software is installed (such as iTunes, Nero, virtual CD software), they install filters into the registry, which can cause compatibility problems.
Follow these instructions to use the Toshiba Upper/Lower Limit Repair Tool to make the CD / DVD drive reappear in Windows Explorer (My Computer):
  1. Click the following link to download the Toshiba Upper/Lower Limit Repair Tool Save the file to the Windows Desktop.
  2. For Windows XP, double-click the file RmvFltrs.exe on the Windows Desktop to start the installation program.
    For Windows Vista, right-click the RmvFltrs.exe file, and choose the "Run as Administrator" option. If a User Account Control dialog box displays the message, "An unidentified program wants access to your computer", click Allow.
  3. Follow the onscreen prompts to complete the installation.
  4. Restart the Computer.
Here is additional information and detailed instructions for manually editing the Windows Registry to make the CD / DVD drive reappear in Windows Explorer (My Computer).
1) Run Regedit (Start -> Run -> Regedit)
2) Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}
3) In the right pane, delete the "UpperFilters" key, and delete the "LowerFilters" key.
4) Reboot.
If your CD/DVD programs stop working, you will need to reinstall them (preferably with an updated version).
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Mar 05, 2013
SOURCE: Where is the location of the CMOS Battery on a Toshiba Satellite P105-S6084
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/big/toshiba-satellite-p105-17.jpg
Right there. Top of motherboard.
http://www.ebay.com/itm/CMOS-RTC-Battery-Toshiba-Satellite-P105-Series-NEW-/150447093156?pt=US_Motherboard_Components&hash=item23075875a4
RTC Battery.
Real Time Clock Battery. Same as CMOS Battery.
http://www.insidemylaptop.com/my-toshiba-laptop-displays-password-prompt-on-startup/
Regards,
joecoolvette
I have lines down the screen. It is getting worse every day
Looks like you will be forced to check out ebay for a new screen. It is a problem with the processing actually in the screen usually. Check it first with an external screen.
1helpful
There is a transparent column on my toshiba p105-s6084 screen. is there an easy fix? Or, do i have to buy another screen?
If the problem is also on an external display then maybe Windows Side Bar is loaded with no gadgets.
Otherwise a replacement screen is the answer.
See ebay for prices and availability.
3helpful
Does the toshiba satellite p105 s6084 support ACHI
Thanks.
I have a toshiba p105 s6084 and after win xp was installed i cant find the drivers for the monitor i tryed there web site but just dont know what to download for some reason i cant right click
You need to know the maker of your display card in the laptop. Once you have that information you can visit their site and download the appropriate diverrs for your adapter. Pess "Start" and goto "help and support" ->'use tools to view.....->'advanced system information'->view detailed system information'->'components'->'display'.
The name of your display adapter will be displayed at the top of the list, like this..>.Name Radeon X300/X550/X1050 Series.
When I play DVDs in my toshiba p105-s6084, it skips in sound and sounds all sketchy. It plays cds ok. what is wrong?
Sounds like you need to update the DVD Decoder, A very good decoder is Nvidia, roxio and Power DVD are ok. Hope this was helpful Good Luck =)
I have a Toshiba Satellite P105-S6084 My daughter turned it on. Windows started to load and then everything went blank and the computer refused to be turned on again. No sign of power
P105-S6084 Does not turn on at all.
i think you're right!you have to replace a new one honestly
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
