Question about Kenmore Washing Machines
I am having trouble replacing my belt on my Kenmore 70 series
I am having trouble replacing my belt on my washer. Is there a step by step solution? My washer is older but is good. Kenmore 70 series
82372810
    Sergeant:
  • 272 Answers
I've got them down to 10 minutes, but here goes. remove the bolts going into pump, but do not remove pump . remove the transmission bolt with the spacer and this is where you push the belt through and around pulleys.. this is a little more difficult. you will need to take off the yoke spring and move the transmission pulley around until the spin control magnet catches for spin. it will begin to take pressure off of clutch. you will need a long screwdriver or something like it to apply pressure down on the clutch plate this is to allow to to slip the belt thru the bar the spring came off of and under it.. you can then pull the belts around all pulleys and put everthing back in its place and your done...
Posted on Jul 19, 2009
My Kenmore 70 series washer only fills will hot water
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore 22422 Top Load Washer
Shavings and grease on washer pan under my Kenmore 70 series
It appears your clutch assembly or bearing has failed in this instance.
Dec 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 model 110 82376810, timer know
Appliance parts places don't stock the timers because they hardly ever go bad. Troubleshoot first! .I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 30, 2009 | Kenmore 24032\24036 Top Load Washer
70 series how to replace belt
the kenmore 70 series do not come with belts they have a coupler behind the motor. Fairly easy to replace you can actually find videos on youtube.com to walk you through how to change it.
Oct 02, 2009 | Kenmore Washing Machines
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Belt replacement on kenmore 70 series heavy duty plus
No belt on this, its a direct drive with a motor coupler..There is a tutorial for this at www.shop.washermd.com Dave
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
192 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
