Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Gas is not going thru the engine - Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
    Problem Solver:
  • 13 Answers
It all starts in the carb...
most problems with starting usually always start in the carb..i get dirty cleaning everything and often hook a dry hose up and blow through my holes in the carb...even blowing the jets...
if you cant blow air through it...you aint blowing gas through it
Posted on Jul 21, 2009
Lincoln ranger 8 and kohler engine command 20. engine does not pull gas to carburetor. Putting little gas directly in carburetor; machine runs until finish gasoline inside carburator.
engines don't "pull" fuel to carb , it either gravity flows (tank over top carb) there or its pumped there , I do believe the kohler engines from 8 hp thru 25 hp use a vacuum activated fuel pump (three hoses on it) these do go bad over time and need replaced , also there are fuel filters on all these engines that need to be replaced seasonally they are not cleanable there disposable
Dec 15, 2016 | Kohler Electrical Supplies
Will a 2011 2 litre diesel motor fit a 2011 1.6 litre diesel VW Golf
If you drain out the gas from tank and fuel lines and turn over engine the old one may work without replacing engine . Call a good junk yard to veify fit of used engine and transmission .
Nov 08, 2014 | Haynes VW Golf, GTI & Jetta Repair Manual...
Engine starts then backfires and sometimes leaks gas on exhaust
IS it leaking gas on the exhaust or thru the exhaust. I have seen the float in the carb stick in the down or fill position and flood thru the exhaust.
Sep 04, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
My 94 econoline van wont stay running
bad gas maybee? Use gas treatment and change fuel filter i would try the most inexpensive solution first
Oct 29, 2012 | Haynes Ford Full-size Vans Repair Manual...
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
03 tiburon 5sp i shift from 1st thru 4th if i
The slave cylinder for your clutch has a valve in it, which keeps the clutch from engaging too quickly. The purpose is to keep you from just dumping the clutch and wreaking havoc on your transmission. If you're confident that you don't need that extra safety device in there, you can remove it, just google slave cylinder valve removal. It will give your clutch more of an aftermarket feel.
Oct 02, 2009 | 2003 Hyundai Tiburon
Car starts but need to apply gas to keep it going. Once the gas pedal is released, the car stalls.
Have a look at your fuel sysytem which comprises of injector and fuel pump and the fuel hoses.
Good luck.
Jul 26, 2009 | Toyota Highlander Cars & Trucks
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
114 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
