Question about Compaq Armada E500 Notebook
My external hd does not work, light fashes when i plug it in the usb port!!
  • 3,866 Answers
1. Try it on another computer
2. the external hard drive controller board gave out you can buy a new encloser from like frys.com,tigerdirect.com and have the hard drive put in that.
3. if it works on the other computer then its your usb ports on your laptop not giveing %V of power thus you would need a HUB to amplify that power.
Thanks i hope this helped.
Posted on Jul 18, 2009
Troubleshooting komputer
Use the eject usb device safely feature before unplugging the hard drive.
Change to a different usb port.
Apr 04, 2014 | Toshiba Computers & Internet
Sumvision egem external hdd
more often hardware compatibility issue, try using different usb cable first,
Mar 18, 2014 | Apple Computers & Internet
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
Nov 27, 2009 | Computers & Internet
I have an external 500 GB HD. I try to plug it in to my laptop and the light on the front just flashes. The laptop doesn't recognize the HD, and there is no sound coming from the external HD
For that make sure usb cable works fine.
Try with different usb cable.
Also connect usb cable in different usb ports of computer.
Right click on my computer then click on proeperty then hardware->device manager.
Then click on sign of usb controllers then uniunstall all usb drivers 1 by 1.
then restart computer.
Then check.
If still not recognized then when you power up the computer press F8 key then enter in safe mode.
then check.
in normal mode again.sometimes harddisk need to start in safe mode .
Let me know if you need more assistance.
thanks.
Nov 05, 2009 | Western Digital My Book Essential Edition...
My light is on and a buzz sound is heardwhich stops after a minute and no data is displayed
You do not say whether the HDD ever worked.
If it did, and stopped, chances are that the internal HD is damaged, or the motor performances degraded and it now requiring a higher current than the USB port can deliver.
Try plugging it on a different USB port or, better yet, into an externally powered USB hub. There are also special cables which plug two USB ports into one and deliver double current to the appliance.
As a last resort, it might be possible to recover it by extracting it from its enclosure and connecting to a desktop PC via a 3.5-to-2.5 inch HD adapter.
In all cases, unless it never worked on that PC (which means that the problem might be in that PC's USB port), I'd strongly suggest to back up all data on another disk.
Oct 26, 2009 | Seagate Free Agent Go Small 12 GB USB...
Why does my iOmega LPHD-UP USB external HD not work with 7-Port USB hub? Is it the 500mV limitation per port or something else? Works fine if plugged directly into the laptops only USB port.
you got it! may need to get a 'powered' usb hub. another 'wall wart!', but will probably allow use of hub to power usb hdd!
good luck!
Oct 11, 2009 | Computers & Internet
Problem with accessing my external hard drive
It's probably NOT the voltage, but the current available at a given USB port. You might try using a USB cable that has two "A" connectors on one end that connect to the computer, one for power and data, the other is just for extra power. The other end of the cable should have the appropriate connector for your external drive. By connecting the second "A" plug to the computer, you double the current available to the external drive.
Apr 28, 2009 | Computers & Internet
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Need instructions for eGo portable hard drive. This shold ave come wit th purchase but did not.
there's no much need for instructions.
you just plug the hd into a USB port avaliable in your computer. the operating system should be able to recognize it a few seconds after you have plugged the hd into the usb port.
some hd may require for 2 usb to be connected to the computer for the computer to see it.. usually they come with a "y" usb cord. one goes to the hd and 2 usb type a cord go to 2 usb ports on the computer
to check to make sure the computer sees the hd. go into my computer and check if a removable storage device has appear.
also check your hd is on, some external hd may have switch to turn them on.
also check if your hd requires external power if it does it should come with a power connector that needs to be connected and plugged into the power outlet for it to work.
post your finding if you need more help.
Oct 14, 2008 | Computers & Internet
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
Compaq Armada E500 Notebook Logo
37 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
