Question about Ryobi Garden
Fuel lines rotted and broke. Installed new lines but unsure of proper connections.
  • 85 Answers
Use the primer bulb & determine which nipple has pressure when pushed, that is the return (short line) the other is the pickup line with the fuel filter on it
Posted on Sep 13, 2009
How to change fuel line on craftsman blower
Before you start take a picture of where the old lines are connected to the carb and the primer bulb for future reference.
To replace the line pull the spark plug wire from the plug. Remove the old line from the tank and remove the fuel filter from the line. Take new larger line and cut it on a 45 degree angle/or trim as necessary so you can grip it from inside the tank and pull it into the tank. Perform the same operation on the smaller line as well. Be sure to leave enough line for the fuel filter to reach the bottom of the tank. Install the fuel filter. The other small line is a vent line and only needs to come inside the tank not go to the bottom in the fuel.
Good luck.
Jun 07, 2014 | Craftsman 4 Cycle Blower/Vac
Poulan PP4218 avx; tube (line) inside gas tank connecting filter has rotted and need to replace. Is there a tool used to push line onto "nipple" inside tank.
cheapest way is a new fuel tank from e-bay that has it all installed
you can remove the rubber grommet around the lines to get it out then get a new filter to push on the line BUT will it be cost effective against what can be obtained from e-bay
Aug 01, 2013 | Poulan Pro Chain Saw 46cc 20"
Fuel line leak under the fuel line protector cover
the line must be rotted,under the cover, you will nee to cut out rotted part and splice in a new line.
Oct 04, 2010 | 1991 Honda Accord
I have a 1994 Gran Marquis. Fuel lines are rotting and leaking
Just get a piece of the rotting fuel line so that you will be assured of getting the right size. Take it to a shop that sells car accessories, and ask them for enough to do your car. Also get new clamps. Start at the fuel tank, undo the clamp, pull off the old hose , put on the new one, do up the new clamp, and then just follow the old hose along, replacing it with the new one as you go. At the far end. do the same... undo the old clamp, put the new hose and clamp on. But I forgot to tell you about the fuel filter. Replace this while you are doing this job.
Feb 23, 2010 | 1994 Mercury Grand Marquis
Fuel lines rotted, unsure of routing new ones
Bottom of the tank one is an overflow, 2 in the top are connected to the bulb
. The bulb pumps gas from the gas tank to the bowl of the carb then back to the fueltank in a loop to prime things up, prime too much and the overflow comes out the bottom tube.
Sep 23, 2009 | McCulloch 26cc Gas Blower Mcb3208
1999 Saturn not cranking
it could be the fuel pump or relay maby filter as well any visible signs of vacuum line cracks dry-rot
Aug 25, 2009 | 1999 Saturn SL
1995 ford taurus no gas and or spark
Does the check engine light turn on when you put key to 'run'? It sounds to me like the EEC (electronic engine control) relay is not working. This turns on the computer, which in turn controls the fuel pump relay and spark control. I am unsure of it's location. Possibly under the dash by the passenger kick panel or under the hood. This is what I would consider the most likely cause. It is green in color. The fuel pump relay is in the control box above the radiator and under the plastic panel with the vacuum schematic decal.
Jun 23, 2009 | 1995 Ford Taurus
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
I have an older Weed Eater gas powered trimmer(Model XT 85T) The fuel lines have aged, rotted and broke. I have new lines (big fuel line and small fuel line). How do I get these lines through the holes...
gas line is 1/8" ID. NAPA autoparts sells replacement gas line that works but has an OD that will not fit hole in plastic frame where the carb sits. Just drill the plastic to the OD of new gas line and use needlenose pliers to install the line. Same goes for the gas tank. Just make sure it is tight fit so it does not leak.
Mar 27, 2009 | Garden
Chainsaw won't stay running
try fuel first drain fuel out replace . add small amount of carb cleaner , i like sea foam myself , available @ advance auto or like store then retry might have to restart several time to get into system . if no good then possible diaphragm in carb . but worth a shot before tear down
Dec 28, 2008 | Garden
Garden Logo
166 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
