Question about Panasonic NV-DS60 Mini DV Digital Camcorder
Power Light blinks
Dear Expert,
when I start recording, Power LED blinks and recording dosnt start.
  • 33 Answers
Re: Power Light blinks
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Posted on Feb 21, 2008
0 characters
3 Points
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Recording or playing back
for all of you who have this problem. You can't record or playback anything and your power light is blinking. Just turn it on and off on and off. I did this for about 5 minutes. Just turning off and on and then trying to play or record something then took out the tape and blew with a duster for cleaning your keyboard and that worked. This has happened before and well that worked for me. Hope it helps anyone outthere.
on Jun 15, 2007 | Panasonic Palmcorder PV-DV103 Mini DV...
Why dos tv still blinking red with no power
If you pull the plug out of the wall, it should stop. Otherwise it's a reminder that you have switched it off by handset but it is still live. If the TV works ok, ignore it, it is probably just an economy reminder. If the TV does NOT work, you may have a fault on the power supply board. Have you read the manual to see if it mentions the red light?
Aug 29, 2014 | Samsung Un55d6000 55 Inch 1080p Led Hdtv
How to connect Hitachi camcoder with laptop
Connecting to PC via PC Connection Cable
Use the provided PC connection cable to connect the DVD video camera/recorder to PC as shown in the last.
• No data can be written to the HDD, disc or SD memory card in this DVD video camera/recorder when it is connected to PC.
• The PC connection cable does not supply power to the DVD video camera/recorder: Use the AC adapter/charger
to power the DVD video camera/recorder.
• Before connecting the DVD video camera/recorder to PC, disconnect any cables or camera accessories (external
video flash, external microphone, etc.) other than the PC connection cable and AC adapter/charger.
• When connecting the DVD video camera/recorder to PC, the ACCESS/PC indicator will light green. While HDD or
a disc is being accessed, the indicator will light or blink orange. While an SD memory card is being accessed, the
CARD ACCESS indicator will light or blink red.
If you connect the DVD video camera/recorder to PC via PC connection cable, the PC will automatically recognise the DVD video camera/recorder. After recognition is finished, it may be
prompted to restart the PC: In this case, follow the instruction and restart the PC.
Mar 11, 2012 | Hitachi Video Cameras
Jvc gr-dv800u blinking power light when i plug it in
The camera's battery is charging while the light blinks. When the battery gets fully charged, the led will stay on, indicating that the battery is charged. The manual should explain this, in case you still have it. Good luck, and hope this helps.
Jun 05, 2010 | JVC GR-DV800U Camcorder
Dust problem in Power switch function
1. can of compressed air and some alcohal should work to clean the switch out.
2 make sure the battery is out when your doing it and let dry for 24 hours before replying power.
hope this helps if not you might have to send it to get fixed if there is no one in your area.
Aug 22, 2009 | Sony Handycam CCD-TRV37 Camcorder
Red light blinking
i was filming, and i tripped and my gl2 hit the ground. it hit the battery kind of hard and now it wont work properly. now when i turn it on, the power light blinks red or green, depending on playback and recording mode. i want to know how i can fix this.
Dec 18, 2008 | Canon GL2 Mini DV Digital Camcorder
Red power light flashing on and off
the same thing happens to me! idk how to fix it
May 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
104 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
