Question about E-Machines T2882 PC Desktop
I have a t2882 emachine it won`t turn on light on frount is on but won`t turn on
  • jreed1079 May 11, 2010
    Do you hear any sound when you turn the computer on? Are you just not getting any video?
  • 33 Answers
Check the monitor connection the pc or you may have to buy a video card for your pc.
Posted on Jul 18, 2009
My husband's e-machine T2882 began to make jittery noises the light on the front flashes as does the monitor with a ticking sounds then nothing happens. You can't get it to turn on. We've rebooted shut...
If there's a ticking sound, its probably your hard drive giving out. You have to read what comes on the screen for clues but .....................
You could try booting into safe mode (press the F8 key while booting several times) and completing a system restore. (Start - All programes - Accessories - System Tools - System restore) to a date when it last worked.
If you can't get to the safe mode, then, as its 7 years old, its probably time to treat yourself to a new one.
May 15, 2010 | E-Machines T2882 PC Desktop
My husband's E-Machine T2882 began to make jittery noises, the light on the front flashes as does the monitor with a ticking sounds, then nothing happens. You can't get it to turn on. We've rebooted, shut...
first look for the upgrade of the hardware's inside. like memory and processor. second if that machine is 7 yrs old, please do replace it. coz i believe the hardware's for that is now expensive.
Mar 28, 2010 | E-Machines T2882 PC Desktop
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
Not getting power on my t2882 e-machine.
I am an emachine specialist. These computer suffer with problem motherboards which often blow the power supply unit. Replacing the power supply on it's own does not solve the problem as the motherboard processor socket is the cause of the problem, the fault in turn blows the power supply. The same applies to all Advent and Medion computers sold via the high street stores.
Need help to repair, email me me at compdoctor2005@btinternet.com or ring me on 07926-106150
Mar 19, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
Connections
The main connector to the power supply has to go into the motherboard. Its a rectangle shapped male connector that is on the end of the power supply that plugs into a rectangle female shaped connector on the motherboard. There might also be a shorter square male 4 pin connector at the end of the power supply that should connect into a 4 pin female connector on the motherboard.
After this then you'll want to plug the other connectors into any cd-rom, dvd-rom drives you may have. Same for a floppy drive if you have one. Also make sure your hard drive is hooked up. The connectors that you plug to these devices can only go in one way so no worries about hooking it up improperly. Hope this helps.
After all this, turn on the computer and then after you boot up into windows, make sure you go into my computer and verify that all your drives are being shown in there.
Jan 28, 2009 | E-Machines eMachines Desktop PC
My emachine t2882
Try this : See if you can find your motherboard model number. If so, type it into Google, go to the manufacturers site and download a manual which should have the wiring diagram you require.
Cheers.
Lost all sound after clean install.
reinstall the drivers from motherboard cd or download it from manufacture website
Apr 23, 2008 | Computers & Internet
EMACHINE t2882
Are the pins from the switch to the motherboard connected properly?
Could be a faulty switch on you case. T
ry shorting out the two power on pins (on motherboard) with a screw driver but be carefull not to touch anything else with it!! :)
hope this helps?
Jan 06, 2008 | E-Machines eMachines Desktop PC
E-Machines T2882 PC Desktop Logo
137 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
