Question about Whirlpool Duet GHW9150P Front Load Washer
Clothes coming out spotted - Whirlpool Duet GHW9150P Front Load Washer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hi Residue builds up inside of washing machines for all sorts of reasons. Many detergents and fabric softeners can leave filmy layers behind. Hard water can cause spotting on both plastic and metal thus ending up with spots on your washing, how to resolve this follow the instructions, 1, use vinegar a bottle and place your machine on the hottest wash cycle and let it run through a full cycle, when finished use a paper towel with vinegar to clean the inside, set machine on a rinse cycle, this may need to be repeated but will solve it, also use gels and liquids instead of powders and descale etc.
Posted on Jul 19, 2009
Clothe comes out with spotting marks. What is problem, what is to be done?
Possibly the powder. Try filling the machine first with water and power, mix well and then add the clothes? Putting powder onto dry clothes in the machine may be causing localised bleaching.
Sep 19, 2014 | Admiral AW22 Top Load Washer
Leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
May 09, 2010 | Washing Machines
Oil spots on clothing from washing machine - GE top loader
faulty clutch seal, Not a DIY
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Washing Machines
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Spots on clothes
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Dec 02, 2008 | Kenmore Elite 45986 Front Load Washer
DRYER CAUSING SPOTS ON CLOTHES
maybe you have high iron content in your water?? if so theres a product called iron out. supposedly it works well. good luck
May 23, 2017 | Kenmore Dryers
Grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
240 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
