First no picture, replaced fault lcd drivePCB, now white screen, no Functions no OSD
  • kemptv Jul 18, 2009
    Model Conia LCD CLCD1930 DSD
    have no diagram to check voltage rails to other pcbs any Idea ?
    thanks frank
  • 5,807 Answers
since you replace the LCD drive the problem now is on the digital board
have it replaced if you have replacements
check also power supply board
hope this helps thanks for using Fixya!
Posted on Jul 19, 2009
  • 3,741 Answers
The connections are not proper or also any other capacitor or ic is getting short. check out on the board to clear the faulty.do nt keep the tv on for more time as if its short it can short the new pcb also. thanks. Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 18, 2009
How to fix an all white scrren on lcd tv
Check and replace its T'Con board. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 23, 2016 | Televison & Video
Hi, Need help with ProScan TV mo#32LB30QB.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 25, 2016 | Proscan 32LB30QD 32 in. LCD TV
Why is there a white vertical bar down the middle of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 28, 2015 | Televison & Video
Vizio model #E322vl picture screen is a frosty white no color.there's sound and images.it's frosty white (the screen)
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 01, 2015 | Vizio Televison & Video
My display screen is white..all other camera functions are fine
Identify whether the LCD is bad or not. One way to do this is to take a picture with the camera and then download it to PC. If the picture looks good, then the LCD screen is bad. Replace LCD. Easiest way is to buy through EBAY a damaged camera with good LCD. You may be able to get it very cheap. Then replace it yourself. Remove few screws on the case, open the case. Usually, LCD can be easily removed once the case is open.
Jan 03, 2011 | Casio Exilim EX-Z750 Digital Camera
The image in the viewfinder is now black and white and the LCD screen doesn't work
iam very sorry that you have this problem.When an LCD screen of DSRPD170P stops working it means that you have to get a replacement LCD screen. The replacement requires a qualified technical person. if you have such a person , then here are the details for ordering the LCD screen parts:
A-7078-956-A PD-217 board complete.
8-753-209-13 ACX500ENA
1-517-931-21 Tube fluorescent cold cathode.
Please note that the viewfinder of the DSR PD170 camera is always manufactured and supplied as black and white (not colour) so this is not a fault!
Oct 08, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
White screen of doom.
If your screen is completly white then unfortuanetly the screen itself will be at fault & would need to be replaced. On some LCD models there is a small fuse on the drive board attached to the screen, again on certain models this can be accessed & replaced but there is no guarentee that this is the only problem.
Aug 17, 2009 | Televison & Video
The part behind the lcd screen is broken
I think you need to replace the screen module, from your description of the fault. The 'part behind the screen' IS the LCD module - the front part is for protection. As you can still take pictures and store image files, it is just the screen at fault.
Dec 22, 2017 | Nikon Coolpix L11 Digital Camera
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
OSD Menu won't turn off
Known issue -- can get a replacement if still under warranty. The planar rma techs are really really nice.
May 13, 2007 | Planar PE170 White (Black, White) 17 in....
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
