Question about Maytag Atlantis MAV6000 Top Load Washer
Mav6200 pump comes on and drains water but machine never spins???????????????? Help Please!
  • 520 Answers
Try spinning the tub by hand. It should only go one way. If it spins then it is free and the transmission is most likely ok. The door switch is the problem. If the door is not switching ok then the clutch will not engage and it will never spin or agitate. Have the switch replaced and that will have you back in business. Hope this helps. Good luck.
Posted on Jul 18, 2009
  • 44 Answers
I agree with cj2176 also try air pressure switch,it might not be resetting.
Posted on Jul 22, 2009
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Hotpoint aquarius 100 wm62
tha model number doesn't come up,you need to send the full number off of the washer,open the door and lok around the opening where you put the clothes in,you should see a tag with the model number on it,if the pump doesn't drain out the water then it can't spin until the water is drained,if it's a front load washer check the pump to see if something is in the pump stopping the impellar from spinning to drain out the water or you could have a bad pump,put the washer or drain and spin and see if it will drain.
Jun 06, 2013 | Washing Machines
Kenmore elite model 110.2808 does not drain and does not start to spin
After the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin. check the output to the drain valve if absent the control board is a suspect, if not clean the drain pump;
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
ttp://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Feb 28, 2013 | Washing Machines
Maytag mav6200 top load washer leaving an inch water in tub, disconnected the water pump to remove a small stuck piece of metal when it was squealing loud, replaced everything and now it leaves an inch of...
The piece of metal you removed came from around the pulley assembly on the pump? There is an updated drain pump that is for that model and should be replaced. The original pump was a bad design and fail quickly. Here is the new pump that I would replace it with and all will be good. It has a higher volume that it will pump out. The reason the current pump is leaving water is that the timer is finishing it cycle before the pump is able to remove all the water.
Please let me know if I could be of further assistance to you.
Richard Roth
Oct 13, 2012 | Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 12, 2010 | Kenmore Washing Machines
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
heatman101
Oct 12, 2010 | LG WM1812C Front Load Washer
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
274 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
