Question about Gateway HD1900 19" Monitor
Monitor not powering up. Theft deterrent?
My monitor is not functioning properly. It is only turning on "When it feels like it," usually after I wait 5-6 hours with the power cord out.
It is a 19" Gateway.
I unplugged my monitor from the wall and plugged it into a new outlet. When the display turned on, Theft Deterrent mode demanded I type a number in to continue. The code was wrong and the window closed, and the monitor continued working.
The next time I shut off my computer my monitor shut down completely. There is no LED light on, even though the cord is plugged in. I unplug the monitor and wait for 5 minutes, and when I plug it in the LED flashes once and then the monitor shuts off again.
If I wait a long time, multiple hours, the monitor comes on when i plug it in. Sometimes.
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 18, 2009
Tip
Gateway LCD monitor EZTUNE theft protection problem
You need to install EZTUNE but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
on Apr 14, 2010 | Computers & Internet
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: https://pinreg.portrait.com/index.php?OEM=gwy&PRODUCT=dtune&ULANG=enu .
The EzTune software is available here: http://oem.portrait.com/dtune/gwy/enu/upgrade.html .
The user's guide and other documentation is available here: http://support.gateway.com/s/MONITOR/7005574R/7005574Rnv.shtml .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
My lcd mode no HP L1750LCD a massage seems on my screen that theft mode enabled, as such it is requested that kindly solve my problem.
Hi, you can solve your problem to follow these instructions.Open the HP Display Assistant.
  1. Click the Plug-ins tab.
  2. Click the Theft Deterrence button.
  3. Click the Disable Theft Deterrence button.
Good Luck
Feb 24, 2011 | HP L1750 LCD Monitor
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
Theft disable menu pops up and won't go away and it keeps turning off my monitor
You need to install EZTUNE from Gateway, but you need to go here first:
User manual:
http://www.retrevo.com/support/Gateway-FPD1975W-Monitors-manual/id/1071ag416/t/2/
Apr 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back it...it should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Anti theft mode
If L90D you need a PIN number to unlock it.
Connect to your original computer and run Plug-ins - Theft deterrence to enter or reset PIN - or go to web site via software - see below
http://www.hyundaiq.com/Eng/DownLoad/MonitorDri/View.asp?page=1&SchSel=&SchStr=&idx=87&V_nm=30
Under the ‘Plug-ins’ menu is the ‘Theft Deterrence’ option – a more accurate term than the ‘Anti-Theft’ sticker on the monitor itself. Why? Well anyone can physically steal this monitor from me. There is no Bond-like lethal gadget that would bring certain death to a would be thief. Rather, the theft deterrent is a PIN-based procedure that hinders the operation of the display once it has been removed from the host computer. Briefly, you register and store a PIN to a secure web site, then set a countdown timer. If the power and display cables have been removed and the monitor has been attached to a different computer, the timer counts down. If the correct PIN is not entered using ImageTune, the monitor will enter theft mode and display a large warning message. It doesn’t prevent the monitor from being swiped, but at least there's some satisfaction in knowing the thief can’t use it.
software called ImageTune that replaces the usual on-screen display (OSD) tools, arrives on an included CD. With it, you can adjust basic monitor settings such as brightness and contrast with a mouse instead of with the small, squishy membrane buttons under the bezel.
Apr 03, 2008 | Hyundai L90D+ 19" LCD Monitor
Gateway HD1900 19" Monitor Logo
466 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
