Question about HP Deskjet 6980 InkJet Photo Printer
After changing cartridges in deskjet 6980, door does not securely close on the right hand side, so therefore it will not print..what could be the problem? have checked everything,nothing binding it.
This isn't technical at all, but I find I need to just give the top upper right hand side of the door a firm shot with the heel of my hand and that sets it back into place where it will print again.
Good luck.
Posted on Aug 07, 2009
I have an HP Deskjet 6980. After changing the black ink cartridge i tried to print. The printer takes the paper but doesnt print, just the Power and the resume lights are blinking. If I press the resume...
The printer might be working but the cartridge is not connected properly. Just open your printer, remove the cartridge and replace it back in its right position.
Mar 25, 2011 | HP Deskjet 6980 InkJet Printer
The door does not close on the right side on my deskjet 6980
On the HP 6980 et al printers the right side of the lid does not completely close. The reason is a design flaw. If you pull the bottom of the right side cover out no more than 3/8" to release the clips and then lift it up you will reveal the lid gears and lid closed switch pawl. The area where the switch pawl contacts the lid gear needs generous lubrication. If that fails then removing the sharp edges of the contacting areas will be required and then the lubrication.
Jan 26, 2011 | HP Deskjet 6980 InkJet Photo Printer
I need to change the cartridge on my HP deskjet 6980. I don't remember how.
Here is a step-by-step tutorial on how to change the cartridges:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00569593&lc=en&dlc=en&cc=us&lang=en&product=467982
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 14, 2009 | HP Deskjet 6980 InkJet Printer
Hp deskjet 6980 - green light on key beside the lock
it can be the problem of cartridges got faulrty so that needs replacement any of the two cartridge can be faulty. or the wire less connection issue.in that caee just conmnect the printer with a usb wire and check out.if same problem in connecting wire then its cartridge issue foir sure.
Feb 26, 2009 | HP Deskjet 6980 InkJet Printer
I have an HP deskjet 6980. I have had it for over a year but a couple days ago I changed the black ink cartrigde and an orange light stayed on while a message read that the door was open. This printer...
Here is the solution. Sorry the expert above was vague. (Sorry mate but it is hard to believe you are an expert when you can't write properly or spell even close. Good luck in the future if you work hard and improve your skills)
Below is the solution provided by HP it works.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01065334&dlc=en&product=467982
Following below is the thread from a forum that used the above solution and their results. All worked with step 2 from above once it was verified that there is no paper jam.
Also don't waste your time with HP support. They know nothing of their own tech bulletin.
ref: HP Deskjet 6980 series, 6XXX series, Door open error
Oct 03, 2008 | HP Office Equipment & Supplies
HP DeskJet 6980
Sometimes the top does not "click" into place in the top right hand corner. Give this a firm push down and you may hear a click, I had this problem a few times and this solved it.
Jun 18, 2008 | HP Deskjet 6980 InkJet Photo Printer
How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Jun 13, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6980 InkJet Photo Printer Logo
172 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
