Question about Mach Speed P4MBMS Motherboard
My pc won't boot, either from it's HD or from a CD. I have an POST-PCI-Card that yields an error code FF, which means "correct boot device not found" -OR- possibly "Initialize video". Any ideas?
  • 3,741 Answers
Usually when this occurs, there's some sort of conflict in your Bios settings .its the problem of main board.the bios settings are got corrupted or missing or deleted or getting blocked due to viruses in the system.the main mother board has to be checked by a technician.as he will connect the board to the oscillo and check out the fault in the mother board and through the card reader check the faulty area and reset the bios settings.it requires a perfect professional to do this.it will take good amount of time .and its 50 --- 50 chance.many times the bios setting do not get resetted so whole mother board needs replacemnt. the cost of new board can be near to $70
Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 18, 2009
I have narowed down my problem to the cpu or bios. Is there any way to boot a computer with this problem? A self booting card put into a PCI slot? ****
Problem is not noted, but boot options are internal hard drive, external hd (USB device), optical drive, and network card (could be PCI card).
Dec 11, 2012 | Computers & Internet
I have a T40 IBM that just got the 1802 error. downloaded a bootable fix that I made to a CD. Set both startup and network to look for the CD drive first. Cannot get past the double beep on the POST test...
To correct this issue, you will need to remove the PCI wireless card from your laptop or disable the mini PCI settings in the BIOS menu.
On IBM's, the Mini PCI card slot is usually at the back of computer.
After removing card or disabling the
mini PCI settings in the BIOS menu, boot your computer. Make sure to update your BIOS. The new BIOS version can be downloaded from the manufacturer's website.
(http://www-307.ibm.com/pc/support/site.wss/MIGR-51708.html).
This issue has been corrected in the latests BIOS updates released.
After updating the BIOS, you can reseat the PCI Wireless card or enable the mini PCI settings in the BIOS menu.
Note that once you have removed the wireless card, you will not have wireless connection until you update the bios and replace it.
Hope this helps.
May 19, 2011 | IBM ThinkPad R40 2722 Notebook
My laptop wont boot up. it only goes to the IBM screen and on the top it says error 1805 turn off and remove pci card. and if i go intothe diagnostic boot it says internal pci card shadowed and also says...
The POST error code 1805 for the ThinkPad is as follows :-
1805
Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
  1. Remove the Wireless USB card that you installed.
  2. System board.
Please click on this link for further POST error codes and explainations
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-42321&velxr-layout=print
Jul 03, 2010 | IBM ThinkPad T30 2366 Notebook
JetWay J939GT4-SLI-G always showing "FF"
Try disconnecting all power connectors to the hard drives and CD-Rom drivesin the system. Leave only the motherboard connectors and the video card connector if there is one. Re-seat your RAM and then try. If it boots up, the power supply is being overloaded and it will not power on the PC.
Sep 27, 2009 | Computers & Internet
Booting Problem
Hi there.
You will need to open your BIOS settings, and change your boot sequence/priority so that it includes PCI cards. Save and exit, and see if it then boots.
If you need anymore help, or need me to clarify anything, I'll be happy to help.
Tim
Apr 24, 2009 | Sabrent Serial ATA (SATA) 1 External + 2...
Error Code in Diagnostic 1000-0146 BUT MY COMPUTER WORKS?????
The 1000-0146 is a diagnostic result indicating a failing hard drive. Just because the drive fails diagnostics, doesn't mean it will not function and is may run for an extended period before if becomes unusable. But take this as a warning and backup any important data you have on that drive NOW.
As far as your PCMCIA Card slot not working.
  1. Ensure it is enabled in the BIOS and you have no driver errors in Device Manager.
  2. If those all check out, replace the card cage: http://cgi.ebay.com/DELL-LATITUDE-D600-PCMCIA-SLOT-CAGE-CMD3BE7632_W0QQitemZ280331231481QQcmdZViewItemQQptZLaptops_Nov05?hash=item280331231481&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Apr 13, 2009 | Dell Latitude D600 Notebook
When I insert my graphic card Ati HD 4850,my system does not boot.I am getting post code error 52 -Test memory(clear all extended memory to 0).Also the fan spins to 100% and does not want to stop.Two...
are your system meet the requirement???
ATI Radeon™ HD 4850 System Requirements
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Minimum 1GB of system memory
  • Installation software requires CD-ROM drive
  • DVD playback requires DVD drive
  • Blu-ray™ playback requires Blu-ray drive
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
Dec 12, 2008 | Computers & Internet
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Location PCI slot 5 ?
Hey there cajununo. The error message you get is telling you that your configuration is wrong and/or you are missing drivers. for your installed hardware. Making the assumption that these were recently installed, I will suggest you go back to basics and pull out all unnecessary devices. Get the machine to post with basic configuration and enter bios setup. Enable all the ports or slots required to seat all the devices you are about to install. Save changes and exit to boot. Then, following instuctions that came with your devices, install one device, ensuring all drivers required have been installed. Restart and then move on to the next. This one at a time approach, will allow you to identify the problem device ( if there still is one ). I hope this helps. Good Luck!
Jan 29, 2008 | ASUS M2N-E Motherboard
XFX nvidia geforce 600gt Pci-e Boot Up Problems
many time overclocking the core does this. Same happens when card is overheating. Check both.
Jan 24, 2007 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Mach Speed P4MBMS Motherboard Logo
61 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Gareth Cockram
Gareth Cockram
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
