Question about Whirlpool LSR5132PQ Top Load Washer
Leeking water from some were not from hoses - Whirlpool LSR5132PQ Top Load Washer
  • 5,911 Answers
Leaks on this model washer can commonly be determined by the following:
1. If the leak is coming from the from underneath the front center of the washer, it's usually caused by a leaking water pump. If the pump leaks, it is not serviceable and must be replaced. The following link explains how:
http://www.fixya.com/support/r397094-replacing_water_pump
2. If the leak is coming from the central area under the wash tub, the tub seal may be leaking. You should see tell-tale signs of water tracks on the gearcase (transmission) if this is the case. Also inspect the wash tub for cracks. Since the outer tub is usually made of plastic, it can crack and develop leaks. This repair involves removing the tub. It's not difficult, but can be extensive. We'll cross that bridge if the time comes - post back and let me know and I can give you advice on how to repair and the parts you may need.
3. If the leak is coming from the right-hand side of the wash tub, consider the air dome. This is a small dome located on the lower side of the wash tub with a small air hose attached. This is how the pressure switch is able to determine the pressure change as the tub fills and turn the water off when full. This air hose can come loose, causing water to pour out while filling (THIS IS NOT A SMALL LEAK). If the air dome is till intact with no cracks the air hose can simply be reattached. If the air dome is damaged, the tub will require replacement.
4. If the leak is coming from the rear of the washer, you will need to check your water inlet valve and associated dispenser hoses. The following link explains how to access the valve and replace (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Of course, your drain hoses are always suspect. You mentioned those hoses weren't leaking. However, if you have not removed the washer case and inspected them closely, you may want to double check them.
If you have any questions, please let me know. I hope this helps you locate your problem.
Posted on Jul 19, 2009
Vehicle is losing water. Already changed water pump. Unsuccessful at resolving issue.
are the carpets in side dry might be leeking from heating unit cylinder head jackets leeking you would see the water running down the sides of the engine split hoses leek in radiator or expansion tank hoses how much does it lose has the mechanic done a pressure test there could be a crack in the block or cylinder head a pressure test would find all these leeks
Mar 26, 2015 | 2003 Buick Regal - Supercharged 3.8L V6 -...
My radiator hose popped off today iput it on and my car still over heats
You may have an air pocket with no fluid. This would cause over heating. If you have a recovery tank, it is better to add fluid thru there and not directly in radiator neck.
Sep 22, 2014 | 2001 Lincoln LS
Water in car
I suggest taking a garden hose and have someone spray your car while you are inside finding the leek stop the leek first .Take a house fan and an extention cord out to car, let fan blow on wet area until dry. another idea is to use a hair dryer. If you dont stop leek you will have a mold problem in no time. If this was helpful please leave good feedback.
Jun 28, 2013 | Cars & Trucks
Its leeking water out of a hose and cant see what the hoese goes to
is it water or coolant? aside from the upper and lower radiator hoses the only other hose carrying coolant is the hearter hose that goes to the heater core.inside the firewall. if it is leaking at the heater core. or the core itself is leaking this is a major job. as the heater core must be removed and tested.
Aug 23, 2010 | 1996 Lincoln Town Car
My GE Refrigerator leeks water underneath when it
There is a pan under the the refrigerator that is to catch the water and let it evaporate from the heat from the compressor. The pan may have a hole in it or the little hose is not draining the water into the pan. This should be an easy fix.
Best of luck I hope this helps you:)
Apr 19, 2010 | GE Refrigerators
Coolant leak , changed hoses all 3 on chev cavalier 1994 2.2l. belt is loose,leak below water pump
check the gasket first u may get lucky if not bearing or seal going or gone
Jan 17, 2010 | 1994 Chevrolet Cavalier
Water leeking from hose ,and water not going down thr drain of shower unit
what hose? as far as the drain goes, it needs to have the hair cleaned out of it. Do you mean hand held shower hose? needs tightening or replacement
Jan 10, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
My washer leeks water from bottom even when its not running and just sitting there. Seems after a wash the water hasn't totally drained out and then slowly starts leeking, actually alot of water is on the...
Have you checked the clamp on the drain hose? It may need tightening. All washers keep a small reserve of water in the bottom of the basket tank. If your drain hose hook is too high from the top of the washer, that much more water will be held below.
Aug 13, 2009 | Westinghouse Washing Machines
Water leeks onto floor occasionally.
hello.
Welcome to Fixya.
  • nspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the water pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
265 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
