Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
My freezer will is defrosting too often. It will not get down below 5 dergees
  • GE Master
  • 1,606 Answers
You possibly have a bad number 4 or 5 thermistor , or both .
Posted on Jul 19, 2009
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Sidex side 26 cf... 5 yrs old... frequent water on floor under freezer... freezer temp is erratic and will seldom be below 6, but infrequently will go below 0 setting ..can not keep ice cream
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | GE Refrigerators
Freezer has slight frost built up. Fridge is only slightly cold - set on 7. It is 5 years old. What might the problem be?
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up heavily because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 29, 2009 | Refrigerators
Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
FREEZER WORKS GREAT BUT FRIDGE NOT SO GOOD-COILS CLEAN
Sounds like a evaporator fan or defrost problem. Your freezer should be colder then that, 5 degrees or below. Anyway, any cold air the fresh food compartment gets is blown over from the freezer, verify you can feel the air flow or visually see or hear the fan in the freezer compartment. If that checks ok more then likely your defrost system has a defect. This consists of a defrost timer or adaptive defrost board, a defrost terminator which is just a bi-metal thermostat set typically at 30 degrees or so and a heater element, either a calrod or 1 or 2 glass encased elements. When this system fails you end up with a block of ice on the coils through which air cannot circulate.
Oct 21, 2008 | Whirlpool Refrigerators
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Frigidaire side by side model# FRS6LR5EW6
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks.
To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain.
The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
Adaptive defrost control
Start with the adaptive defrost control board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A �d� in the freezer temperature window and �F� in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. �d� and �F� will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Heater / Thermostat
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Aug 09, 2008 | Frigidaire FRS26R4A Side by Side...
Freezer not working
HEATER-DEFROST
THERMOSTAT-DEFROST
Heater / Thermostat
Aug 01, 2008 | Frigidaire FRS26R4A Side by Side...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
