Question about Keurig Elite B40 Coffee Maker
Heating light stays on
Had machine for 2 months now was working fine , now heating light stays on and nothing else happens no sounds coming from machine.
  • 3 more comments
  • Anonymous Feb 28, 2008
    The machine goes on and appears to heat up but when you put the handle down and push the button to make a cup, nothing happens.
  • Anonymous May 28, 2008
    This is my third machine and same thing happened all 3 times..
  • Anonymous Jun 05, 2008
    Same problem on a 3 month old unit.
  • bigzinner Aug 20, 2008
    I have the same problem, heating light stays on. Nothing happens. We've had this machine 6 months and it sees light use. I unplugged the coffee maker when when we went on vacation for a week. Problem started when we returned. Is there anyway to reset this
  • Anonymous Oct 13, 2008
I contacted Keurig at 866-901-2739. Based on my serial number, I was still within my 1 year warranty. They determined that my heating element was bad, based on the fact that the the area above the power cord was not at all hot, which it would be if it was truly heating.
My new machine will arrive via FedEx in 3 days!
The Keurig rep did also mention that the heating elements are sensitive to hard well water, which I have. They have seen issues where hard water requires you perform more frequent de-scaling of the brewer, depending on water hardness. Alternatively, we may switch to bottled water.
Posted on Aug 21, 2008
    Problem Solver:
  • 13 Answers
Probably your thermal protection have blow-up. you can try to open the brewer and locate it. is usaly around the the boiler and look like a resitance. you can replace it or just by pass(not- recommanded).
Posted on Nov 20, 2007
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
Have a Bosch SHU43C05UC/14 dishwasher. Water comes in, gets heated, but the unit never seems to go into wash cycle, fills, then drains a little.
This may sound odd but might work.
Reset the machine as to start a new cycle. Add 2-4 cups of water. If the machine starts and runs through a cycle then the water inlet valve needs to be replaced.
Good luck
Jan 02, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
Light on but nothing happens
Sound like the diodes stuffed FOR THE MAIN UNIT.
I'd be taking back to the supplier/ STORE
Apr 30, 2012 | DeLonghi BC0261 Espresso & Coffee Maker
Machine does not want to start on any cycle.
Check salt chamber and add salt if empty. Check your inlet water flow.
Apr 14, 2010 | Dishwashers
My air and heat controls do not work (no power)
I had the same problem check out this sight for a possible solution:
May 23, 2009 | 1999 Jeep Grand Cherokee
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Braun kf 580 coffee maker
If the hot plate is tilted then it should be able to be pushed back down until it is completely level. If not then it is damaged. Check to see that it is screwed in properly underneath.
Apr 15, 2008 | Coffee Makers & Espresso Machines
Keurig Elite B40 Coffee Maker Logo
1,661 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
