SOURCE: Lost spring to batterie campartment
I have the same problem. In the interim I have used a small piece of aluminum foil for each battery.
Did you find a place to get replacement spring?
Mark
SOURCE: the spring and stopper allowing coffee to be
Hello camyernj,
The cone stopper has three parts. The plunger, spring, and collar. The collar is very small and sometimes twists or pops off. If you have these parts you may be able to fix it. If not, contact a small appliance dealer to buy a new cone. Hope this helps. Regards, NormanZ
SOURCE: all buttons under my screen wont work,,except the
there is something called the flex. it carries signals from one part of your phone to another. its usually a flat broad wire containing several wires, usually used in flip and slide phones, it probably has a break inside. you should see an expert to change it for you.
