Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
How do i put new line in it - Black & Decker 14" Grass Hog Xp Trimmer/Edger
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
How to change the fuel lines in the 128 Ld Husqvarna Trimmer
Buy some new fuel line then put the line in from the motor side into the tank and feed up and through the opening on the tank. Then you can put on a new filter with a tiny clamp then put it back into the tank making sure the filter is resting on the bottom.
Apr 22, 2015 | Husqvarna 128 LD Weedeater
55 rancher fuel line
I put a stiff wire inside my gas line and put a little oil on teh grommet,
Feb 01, 2012 | Husqvarna Garden
How to put new gas line from carb totank
Cut the new one at an angle like to a point then run into the tank take a wire ( I use a short piece of coat hanger with a U bent in it) and fish the line out put on the filter then drop the filter back in the tank with plenty of line so the filter is at the bottom of the tank then run the line to the carb and cut any excess off and put on carb
Feb 12, 2011 | Poulan 25CC Gas BlowerVac
How to repair leaking fuel lines under the tank
Okay, prepare to get some gas on you. You need to drain the gas
You'll need:
1 pair hemostats or hose pincher
1 pair of wire cutters
1 screwdriver phillips or flat head
1 nut driver 1/4 inch or 5/16 inch
New fuel line. (cut 1 two inch piece and put the bolt in one end making a plug) = 2 inch plug
Hose clamps.
1 Bolt that will fit inside fuel line.(make line plug)
Pinch either side of the fuel line with hemostats. Cut the factory clamp off and pull the hose off. Put the 2 inch plug on the tank,and that will stop the gas from coming out. put a hose clamp on it if you want so it don't leak.
Now put a gas can under the pinched line and unpinch it and let the gas drain out of that tank.
When done draining , cut that hose off the tank and put it on the other side where that plug is. Remove the plug and put that line on and let that tank drain.
Once the tanks are drained., Just cut the hose to length and replace, using new hose clamps and new fuel line.
If your quick enough you can swap the hoses out without draining the tank.
You will get gas on you no matter what.
Dec 02, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Replace fuel line
You can cut the line, push the fuel filter and fuel line attached to it out where you fill it with gas. When you are ready to put new line in, cut the fuel line at an angle so you can push it in the hole. Keep pushing in until it comes out the fuel tank fill hole. Attach your new fuel filter to the line and pull it back until the fuel filter lays in the bottom of the tank. Then cut the line to length and put it on the carburetor. Take the other piece hook on the carburetor and put it back in the tank.
Sep 28, 2009 | Echo Garden
How to load new line
Well i don't know what kind of line holder yours has, but they either a bolted on with a big nut that you'll need to unscrew while holding the line holder(so your not just spinning it around) or it has a slip and lock type cover, which in that case you hold the barrel of the line holder and then grab the cover and twist it to take it off, then you just take out the line spool, and put new line in it, their will be little holes that you put the start of the line in (pay attention to how you pull out the old line and put the new line in the same way you took out the old line), then just assemble back together and make sure you pull 3-6 inches out through the line holes on the barrel before final assembly and you should be good to go.
If that doesn't work for you, then take it to your local home depot or lowes or lawn and garden hardware store and they will most likely just show you real quick how to do it in person, should be free unless their greedy:)
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Fuel lines
you can buy a repair steel line that is taperd on one end you can cut your old line off flush then insert new replacement in the hole then put jbweld on the connection which will seal up the seam then put rubber fuel line to connect the new line to old line
Dec 31, 2008 | 1990 Geo Prizm
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
380 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
