Question about Hitachi 15 LCD Monitor
Hp 2035 Screen touched too hard,
Now a square exceeding the touched area is black. Is this repairable
  • Hitachi Master
  • 3,866 Answers
This is not repaireable but the screen can be replaced for under $100 bucks and you can get them off of ebay.
thanks
Posted on Jul 18, 2009
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
HP laptop screen problems
This might be an issue with OS itself or display drivers.Once try to reinstall the display drivers.
Dec 08, 2009 | HP TouchSmart tx2z
Acer widescreen extend sides when setting old resolution
You have entered the area between a rock and a hard place. The older games are not aware of the possibility of a wide screen. Either put up with the fat and large images or get a second 4X3 ratio monitor for your older games.
I do not know of any driver to do what you are asking.
Aug 03, 2009 | Computers & Internet
Unfortunately, no. The crystals have been broken.
Jul 18, 2009 | Hitachi 15 LCD Monitor
HP DV4000 Widescreen desktop image does not fill screen
go on u deksto click with right-properties-display setings and change the resolution.
Jul 01, 2009 | HP Computers & Internet
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
BLACK SCREEN ON hp 2035 - GREEN LED ON BUTTON IS LIT
If they are still under warranty, contact HP. If not, it may not be worth repairing. Sometimes a leaky power capacitor can be fixed. Otherwise the other components are surface mount and are very tricky to diagnose/repair.
Dec 03, 2008 | HP Compaq FP 7317 17" Flat Panel LCD...
Front Panel Display is Blank - only small black squares
the front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Jan 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
154 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
